Old 12-07-2006, 06:38 PM   #1 (permalink)
crookbond's Avatar
Default IS 256MB AGP card = (near about) 128 MB RAM + 128mb AGP card
Hey Experts,
I have a query for you.
I like to know, do I have to purchase 256 mb ram of graphics card or can I achieve a near about performance by assigning 128 mb of my RAM to graphics card(128 MB) from BIOS.
Scenario:
Also I want to know the price difference in 6800 GT of 128 mb and 256 mb card.
I am using 1 GB of RAM in my system.
crookbond is offline
Old 12-07-2006, 08:10 PM   #2 (permalink)
deathvirus_me's Avatar
Default Re: IS 256MB AGP card = (near about) 128 MB RAM + 128mb AGP card
no .. the card should have its own local texture mem.
Also , 6800GT's are no longer manufactured , and u won't find any 128 MB ver. around .. u'll have to get a 6800GS instead ...
deathvirus_me is offline
Old 13-07-2006, 12:07 PM   #3 (permalink)
mayanksharma's Avatar
getting 128MB would be quiet difficult i say.But yeah,256MB version is still available at few outlets,if you can try.6800GS is a bit scaled down version of GT,but with high end fabrication process.
mayanksharma is offline
Old 13-07-2006, 05:38 PM   #4 (permalink)
you should buy ram and graphic card separately.
Also to make full use of a 6800GT class graphic card you need atleast 1GB ram, 2GB recommended, so 128mb hardly makes a difference there.
Instead of getting a 256mb geforce 6800GS get a 256mb 7600GT which is much better and should cost around 11k.
Alternative:Radeon X1800GTO but it might cost maybe 1-2k more or so.
akshayt is offline
Old 13-07-2006, 08:55 PM   #5 (permalink)
^^Read you idiot... its AGP . How will he fit a 7600GT into an AGP slot? With a hammer and chisel or what . First of all crook whats ur budget?
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
