Old 11-07-2006, 07:58 PM   #1 (permalink)
Default About processor speed
I have configuration
Processor: AMD Athlon XP 2400+
Motherboard: A7S266-VM
RAM: 512 DDR
It shows a speed of 1.51 GHz, whereas my friend has the same processor and he gets a speed of 2.01GHz (without overclocking).
Please send me an answer to this problem
pushkar1986 is offline
Old 11-07-2006, 08:27 PM   #2 (permalink)
samrulez's Avatar
Default Re: About processor speed
RAM: 512 DDR
Well Athlon XP has two models......one was Thoroughbred and don't exactly remember the name of the other....
so that's the stock speed of ur processor
Sam :D Rulez :lol:
samrulez is offline
Old 11-07-2006, 09:03 PM   #3 (permalink)
Is there a diff in your mobos and ram modules?
There can't be so much diff between 2 different cores.
akshayt is offline
Old 12-07-2006, 01:12 AM   #4 (permalink)
deathvirus_me's Avatar
1.5 GHz !!! thats strange ... did u change any jumper ??
deathvirus_me is offline
Old 12-07-2006, 01:42 AM   #5 (permalink)
There should be a CPU speed jumper somewhere on the board. Your FSB is running at 200MHz. It must run at 266 MHz. Check your mobo manual.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 12-07-2006, 08:30 AM   #6 (permalink)
If I remember correctly, the earlier XP2400s were of 2Ghz speed and later ones with somewhat lower speed and probably larger L2 cache. But I also dont think the differnce was this much.
V.Prem Kumar
janitha is offline
Old 12-07-2006, 08:16 PM   #7 (permalink)
two XP 2400+ .. Barton and Thoroughbred's .... ht former was 2.0 GHz (i think) with 512 KB L2 , while the later was the same 2.0 GHz with 256 KB L2 ... thats all ...
Old 12-07-2006, 10:22 PM   #8 (permalink)
One link connected with this subject:-
http://forums.amd.com/lofiversion/index.php/t19183.html
V.Prem Kumar
janitha is offline
