Old 11-07-2006, 05:42 PM   #1 (permalink)
Question Sata card opinions required
guyz i have been thinking to buy a sata harddrive my budget is 4.5k but the
problem is that my mobo(845g) does'nt support sata i was thinking of buying sata cardand i am in no need of upgrading my system for atleast 2 yrs
Is the performance of the card good or not ?
Will my mobo support pci card boot?
what is the price of the card?
techmax is offline
Old 11-07-2006, 05:50 PM   #2 (permalink)
samrulez's Avatar
Default Re: Sata card opinions required
Well the performance of the card depends on which card is it..the brand.....quality etc.......BUt its a little hard to find the card.....but available.....Once u get it try it with ur friends hard disk and get ur own SATA hard disk...coz if u don't like the performance then the SATA hard disk will go waste...
Sam :D Rulez :lol:
samrulez is offline
Old 11-07-2006, 05:54 PM   #3 (permalink)
I just added a SATA 250gb segate to my 845glad mobo.
I had to buy a SATA to IDE convertor card for Rs 500/- single HDD, the same is also available for Rs 1200/- & supports 2 sata to IDE disk.
Speed difference is negligible but so was the price difference so I better have latest technology.
You may want to read this
http://www.thinkdigit.com/forum/show...187#post251187
ranjan2001 is offline
Old 11-07-2006, 06:09 PM   #4 (permalink)
samrulez's Avatar
But now...the final interface is PATA itself.....what's the use of SATA if u r converting the SATA to PATA.....get a PATA instead...
Sam :D Rulez :lol:
samrulez is offline
Old 11-07-2006, 06:12 PM   #5 (permalink)
When I upgrade I would have a sata disk with me rather than lugging the old pata disk in the new comp.
Old 11-07-2006, 06:14 PM   #6 (permalink)
deathvirus_me's Avatar
Lol ... atleast is he gets a SATA now , and then later upgrades , he can use the same Hdd ...
deathvirus_me is offline
Old 11-07-2006, 07:40 PM   #7 (permalink)
ok the options are good but will i be able to boot from that hdd
techmax is offline
Old 11-07-2006, 08:16 PM   #8 (permalink)
samrulez's Avatar
Yes u will be able to boot from if u disable the onboard one......
Sam :D Rulez :lol:
samrulez is offline
Old 11-07-2006, 09:30 PM   #9 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Not recommended.. IDE to SATA converter is crap.. They just fooling you.. Actually you may even get lesser speed than an IDE disk!
kalpik is offline
Old 11-07-2006, 09:38 PM   #10 (permalink)
why don't you get pata, i don't know whether you will find one though.
akshayt is offline
Old 11-07-2006, 10:44 PM   #11 (permalink)
Just to be sure that speed is not reduced, I ran benchmark test on old disk & then via convertor to the new disk, I did not find any speed loss. Just booting up takes bit more time as it needs to detect the sata drive via convertor.
So why would you say that speed may be less than IDE, no body is promised nor can they get sata speeds when using sata to pata convetor.
The difference was Rs 325/- for a 250 gb, hardly any speed difference, neither slow nor fast, so why not have latest technology so that can be used when you upgrade.
Every 3 years the technology is overhauled completely, but we cant throw our working computers just because the new is available. My PC 1.7/ 845glad mobo is perfect & running, just needed upgradation for space & ram.
Old 12-07-2006, 08:59 AM   #12 (permalink)
GaurishSharma.com
gary4gar's Avatar
u can buy a sata hdd along with converter but i will not remmond u to do so
gary4gar is offline
Old 12-07-2006, 10:28 AM   #13 (permalink)
It would be nice & quite helpful for all of us, if you can also give some of the reasons for not recommending it & why it is mentioned as crap?
Old 18-07-2006, 09:19 PM   #14 (permalink)
Smile Re: Sata card opinions required
I Fully Agree With You and Thank you for the PATA to SATA Conversion Card Mentioned in Detail. Even i have a P4 1.7 Ghz Willamette on a Intel D845WN motherboard With PC-133 MHz SD Ram which is serving my computing needs of Internet access, accounts,TV and entertainment perfectly. Like you Said who needs upgradation just because new technology is available. Money does not grow on trees! My PC's Ram is Obsolete of the whole lot but still it does it's job and Runs Windows XP Home Edition. I may also have to take your advise and do a PATA to SATA Conversion as my hard disk has completed 4 years and has bad sectors and may go kapoot any time.I Do not find logic in a full system upgrade as new cpu+mobo+ram will prove to be a overkill for my basic applications and it is better to keep flogging a dead horse as far as possible.
Many Thanks for the article and keep writing such useful tips.
Fate Will be that of King's and Counsellors of earth who built for themselves palaces now Lying In ruins!
Zaysen is offline
