Old 10-07-2006, 08:04 PM   #1 (permalink)
blueboy83's Avatar
Question MOTHERBOARD Woes!!!!!!! Please Help!
Hi! Here's the deal! I am going for a brand new Machine!
I wanted to know about the Motherboard which I can comply with Inter Pentium Dual Core type processors.. Please Suggest a motherboard which is amazing on performance.. I want to know about
1. MSI Motherboards
2. Asus Motherboards
3. Intel Motherboards..
Also suggest me to opt for AMD or Intel processor?
My Budget is 26 - 27 K!
Please Help!
blueboy83 is offline
Old 10-07-2006, 09:49 PM   #2 (permalink)
samrulez's Avatar
Default Re: MOTHERBOARD Woes!!!!!!! Please Help!
Welll if ur going for Pentium D then go for ASUS mobo.......
for the chipset 945 is easily available.....
For AMD u won't get a dual core processor in ur budget......
Sam :D Rulez :lol:
samrulez is offline
Old 10-07-2006, 09:50 PM   #3 (permalink)
26k on the mobo alone?
if that is your budget for entire system then you are not going to get dual core, only crappy intel ones, not conroe or anything great at stock.
please tell us details.
akshayt is offline
Old 12-07-2006, 04:18 PM   #4 (permalink)
Tux Fan
shaunak's Avatar
i think he means 26k on processor + mobo
my suggestion:
>IntelŪ PentiumŪ D Processor 3.0GHz / 2x2M /800MHz /LGA775 (930) [18k]
(the Pentium D 940 would exceed your budget.)
>Intel D915 GAVL Motherboard (SOUND+AGP+PCI Express 16x slot) (775 pin)(OEM M/B) [7k]
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 12-07-2006, 05:19 PM   #5 (permalink)
If ur more into gaming then definately go for AMD.. atleast 3000+ venice core... coz...
1. its cheaper
2. runs cooler
3. consumes less power
4. better benchies for gaming.
rskbug is offline
