Old 09-07-2006, 04:12 PM   #1 (permalink)
Default RAM problem(maybe....)
Well my computer sometimes hangs, and sometime won't start. My pc-mechanic says the RAM is lose......and if I push it a bit into the slot(I dont feel or see any difference) and restart everything works fine for a couple of days. I hav a D865GBF intel motherboard.....tell me what to do plzzzz.
Paschim is offline
Old 09-07-2006, 04:17 PM   #2 (permalink)
martian's Avatar
Default Re: RAM problem(maybe....)
Well Paschim, RAM may not always be the problem maker... I think the problem is with your PC's SMPS (Power Supply unit). System hangs often when it's SMPS cannot supply enough power to all your PC components.
Please tell me your hardware specs and your SMPS power rating.
Oh my! Such a nice Planet...
But... what am I doing here??
martian is offline
Old 09-07-2006, 04:20 PM   #3 (permalink)
Ummmm.....I hav 80gb harddisk, 256mb ram, 589 virtual memory(lol), and I dont know how to see the smps power capacity....how do i find it?
Paschim is offline
Old 09-07-2006, 04:30 PM   #4 (permalink)
martian's Avatar
Oops! You don't know about your PSUs SMPS rating?? I think it's time you disassemble your system cabinet! It will be on the back of your PSU, say 350W... You got a seperate GPU? What is your Processor? Are you giving power to your Monitor from your PC's PSU?
martian is offline
Old 09-07-2006, 05:15 PM   #5 (permalink)
Connecting the monitor to the bypass socket of SMPS will not overload the SMPS, though it is better to power the monitor from a UPS or mains.
V.Prem Kumar
janitha is offline
Old 09-07-2006, 05:27 PM   #6 (permalink)
martian's Avatar
Oops! I did not know that... I thought connecting a PC monitor to the Cabinets PSU will draw power from the same PSU... Thanx!
martian is offline
Old 09-07-2006, 06:00 PM   #7 (permalink)
samrulez's Avatar
Well ....is ur system overheating??....send us the processor,mobo,hard disk..temp...both idle and at load...
Which SMPS are u using??
Sam :D Rulez :lol:
samrulez is offline
Old 09-07-2006, 07:05 PM   #8 (permalink)
martian's Avatar
See Paschim, SMPS has to be the Culprit! Your PC assembler probably gave you a 300W or lower SMPS... Mm, RAM plays the Culprit on a few occassions though... But if what your vendor says is right, then probably you'll have to service your Motherboard PCI DIMM slot.
Well, what you got to do first is check your SMPS watting... But, you've not mentioned your system specs?? CPU, GPU, etc...
martian is offline
Old 09-07-2006, 07:37 PM   #9 (permalink)
Without knowing about the CPU, Mobo and other periperals we do not know about the probable power consumption and without that it is not proper to accuse the PSU.
V.Prem Kumar
janitha is offline
Old 10-07-2006, 02:53 AM   #10 (permalink)
No pain....No gain
john_the_ultimate's Avatar
@ Paschim
Go here to see ur power consumption: http://www.extreme.outervision.com/psucalculator.jsp
john_the_ultimate is offline
Old 10-07-2006, 05:48 AM   #11 (permalink)
How is that janitha ? I thought the SMPS would be providing power to the monitor then
cyrux is offline
Old 10-07-2006, 06:56 AM   #12 (permalink)
The output from SMPS are direct current voltages like 12V, 5V, 3.3V etc.,while the monitor needs 230V AC because it has its own SMPS like TVs. The socket on the back of the SMPS is in fact a bypass socket giving out the same voltage supplied to it.
V.Prem Kumar
janitha is offline
Old 11-07-2006, 10:48 AM   #13 (permalink)
whatever it is I guess it is out of my hands so I better send it for service. Thx anyways guys!
Paschim is offline
