I keep my system running 24x7 these days. It just gets a break of about 15 mins and then, i switch it on again. (no wonder i've downloaded 15gb in 8days
According to manufactures, the normal recommended working temperature of a hard disk is 35-40°С. Once it rises by just 10°С – from 40°С to 50°С, the safety of its work becomes more than two times less!
If that is true, then my hard disks are in deep $h1t.
The SATA 2 HDD runs at 52ºC and the older PATA HDD runs at 42ºC !!
According to you, what is the normal temperature of a HDD and what is a Over-Heating temperature for it as well ??
Suggestions and comments are needed ....(and fast....)
