as asked above, I'M REALLY CONFUSED NOW.
this is the Specification of my M/B,
http://h10025.www1.hp.com/ewfrf/wc/d...c00300057#N833
NOW tell me what shall i do?????
in that site, it says all these....about the Memory....
->Four 184 pins DIMM sockets support up to 4GB non-ECC 2.6V DDR SDRAM (Register DIMMs is not supported)
->Supports PC 2100 (266 MHz), PC 2700 (333 MHz) or PC 3200 (400 MHz) DDR-DIMMS
What does "Register DIMMsis not supported" mean??????
ALL I WANT TO KNOW IS ..
SHALL I BUY ONE 512MB RAM & INSTALL IT RIGHTAWAY OR DO I HAVE TO BUY1*256 OR 2*256 OR 3*256MB RAM
MY BUDGET ---- Rs.2500/-
Brand-- HYNIX . Currently installed--1*256 DDR SDRAM 400MHz PC3200.
