Re: HDD-Motherboard Compatibility
(if your operating system is using "36 bit LBA" then maximun harddisk size it can detect is 127.4 GB.to detect more than 127.4 GB ,the OS need "48 bit LBA")
new version of sp2 in windowsXP will make your LBA 48 bits, which will support harddisk more than 127.4 G.B
your can make LBA 48 bits also by
download "EnableBigLba.exe" its size is 156 kb and its freeware. run it and it will make LBA 48 bit. reboot.
you never know what you can do until you try
