Hi all,
I m facing problem with compatibily of modem on Linux.
I m using D-Link 562E++ modem. This modem works properly with other Linux applications but with particular application where i m trying to communicate with the server through this modem, it gets disconnected in middle.
Well, D-link specifications tells that this modem is not compatible with Linux. If it is so, how it is working with one application? And if it is not so, what can be the reason, it is getting disconnected?
Any other modem anyone can suggest, which can be used with Linux?
M.R.N.
