Old 03-07-2006, 12:11 PM   #1 (permalink)
Unhappy hard disk rebel
my HDD is out my control ,whenever i load something in my HDD in D: drive after
2 or 3 days it wipe out .plz help me
big B is watching
S.P.Baljinder Singh Isher is offline
Old 03-07-2006, 05:00 PM   #2 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Default Re: hard disk rebel
there must be some virus , try scan with a good updated antivirus like avast , nod32, or Norton.
n00b forever...
~Phenom~ is offline
Old 03-07-2006, 10:02 PM   #3 (permalink)
samrulez's Avatar
Mostly it will be a virus or something.....which anti virus are u using?Get the trial version of NOD32 or Kaspersky and scan it......or update the definitions of the anti virus that u are currently using.....
Get Kaspersky from Here
Get NOD32 from Here
U can try out other anti viruses too.....
Sam :D Rulez :lol:
samrulez is offline
Old 04-07-2006, 12:10 AM   #4 (permalink)
JGuru's Avatar
If you don't have any important files delete the partitions, format & reinstall Windows. This should solve your problem. And keep this as a last resort if nothing
else works.
JGuru is offline
