Old 02-07-2006, 04:54 PM   #1 (permalink)
CT Squad's Avatar
Question Loud Noise from PC-help
I am having Intel 915GAV chipset family and P4 HT processor 256MB RAM, after some time the CPU shouts vvvvvvvrrrrrrooooooooooooooooooom for some time and stops then their again it comes and the process repeats. The computer works fine but still i am afraid that some damage has taken place.
pleae help my PC is my Life...
Success always occurs in private, and failure in full view.
CT Squad is offline
Old 02-07-2006, 06:55 PM   #2 (permalink)
samrulez's Avatar
Default Re: Loud Noise from PC-help
It may be becoz of overheating.....so check if u are getting that sound only when the processor is at load...or even if it idle....Try cleaning the heat-sink with a brush...it might be dirty....Organize the power cables..to ensure better air flow...
Sam :D Rulez :lol:
samrulez is offline
Old 02-07-2006, 07:06 PM   #3 (permalink)
Well theat sound seems to be coming from cpu fan when it might be at full load , check the temperature of the CPU at such instants. Soket 478 processors are prone to overheating
cyrux is offline
Old 02-07-2006, 07:15 PM   #4 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
yeah , that's the prob i think coz when i had a socket 478 p4 , then it used to overheat and the fan made a veru loud buzzing noise when i played games , etc
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
