Old 02-07-2006, 02:37 PM   #1 (permalink)
Default assembled laptops ?
hi
can someone tell me is it a wise decision to opt for assembled laptops, i think it should be quite cheaper than the branded ones, can osmeone tell me is it a wise decision, are there any dealers which assemble laptops in delhi
has someone done this before
jerimski is offline
Old 02-07-2006, 03:51 PM   #2 (permalink)
tuxfan's Avatar
Default Re: assembled laptops ?
IMHO, you should not go for assembled laptops. Compatibility and warranties could be an issue here.
tuxfan is offline
Old 02-07-2006, 07:34 PM   #3 (permalink)
Its not going to be cheaper if you are going for a assembled laptops. Assemebled laptops should be only be taken when you have some extra need, like some extra ram or hdd..other wise the normal branded ones can be taken
cyrux is offline
Old 02-07-2006, 09:18 PM   #4 (permalink)
GaurishSharma.com
gary4gar's Avatar
in laptops for for branded ones only.
gary4gar is offline
Old 02-07-2006, 10:30 PM   #5 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Cool Re: assembled laptops ?
branded laps r gud to a certain extent but ....i dont think deres any delear in India doing the needful.....
Ambar is offline
Old 03-07-2006, 05:58 AM   #6 (permalink)
Learner
Kniwor's Avatar
it is all about ur tendency to take risks and ur knowledge of object and a little factor of luck...
for a person lik me, i would try an assembled laptop...
i wont get a company warranty with it... but the heck, who has ever cared about that, we have component warranty
now one can be cheated, but if u really know what's going on, that not an option, the only place he can cheat you is get a cheap case, laptop casings come in with LCD sceens ready, so u can actually get one and assemble yourself, there is nothing to it...
(whenever i decide on purchasing a lappy, i will assemble myself.)
you get a chance to open it, and coustomize it as per your needs, overclock it or whatever... and that's where is like self made things..
Kniwor is offline
