Old 01-07-2006, 06:35 AM   #1 (permalink)
shyamno's Avatar
Question CD Writer Error ?
Whenever I insert any Blanck CD into my Optical Drive and double click on the CD drive It gives Drive X: is inaccessible even if the blanck cd in present there.
But I have seen in my friend's house it opens and displays nothing as it is blanck.
Is there any settings to be done?Please help.
shyamno is offline
Old 01-07-2006, 09:23 AM   #2 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Default Re: CD Writer Error ?
are u sure u r inserting it into a drive that can write disks not just read them.
Rollercoaster is offline
Old 01-07-2006, 08:05 PM   #3 (permalink)
shyamno's Avatar
Yeah I am pretty sure about that.I had checked it with my CD Writer as well as DVD Writer.
shyamno is offline
Old 01-07-2006, 08:55 PM   #4 (permalink)
JGuru's Avatar
Anyway what brand DVD Writer you are using & how old is it?
Post them here.
JGuru is offline
Old 02-07-2006, 06:48 AM   #5 (permalink)
shyamno's Avatar
I am using Sony DVD-RW and Asus CD-RW.Sony DVD RW is 2 months old and ASUS RW is 2 years old.I don't think there is any problem with these Drives becoz I can Write as well as read CDs from both these.I think there is any problems with settings(might be).
shyamno is offline
Old 02-07-2006, 11:08 AM   #6 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Right click on the writer drive in my computer -> properties -> Recording -> check enable recording on this drive.
kalpik is offline
