Old 01-07-2006, 12:08 AM   #1 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default Keyboard Problem..
recently i am faccing a wierd problem.....my SAMSAUNG keyboard works fine in win 98 but in winXP some of the keys are swapped like when i press the @ on keyboard the " character is printed..... i tried reinstalling the standard drivers(for the microsoft standard 101 keys) no other drivers are included.......HELPPPPPPPPPPPPPPPPPPPPPPPPP....:ma d:
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 01-07-2006, 12:14 AM   #2 (permalink)
JGuru's Avatar
Default Re: Keyboard Problem..
You must have got a software CD with the keyboard pack. You msut install the drivers from it. Or you can download the drivers for your keyboard model from the
Net. If nothing helps you can contact Logitech for help.
JGuru is offline
Old 01-07-2006, 12:42 AM   #3 (permalink)
vandit's Avatar
in the cd there is the software for the hotkey funct. but not the drivers..
vandit is offline
Old 01-07-2006, 02:47 AM   #4 (permalink)
GaurishSharma.com
gary4gar's Avatar
try discount it and then reconnect.
this happens because wrong ping get into wrong sockets
gary4gar is offline
Old 01-07-2006, 07:05 AM   #5 (permalink)
Verify Keyboard properties in Control Panel to see if standard drivers are installed... Have you installed any key mapping software that you may have deleted/forgotten?
Arun
sakumar79 is offline
Old 01-07-2006, 09:21 AM   #6 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
goto control panel>refional and language options>languages>details
varify both options here that the keyboard is US English.
Rollercoaster is offline
Old 01-07-2006, 02:08 PM   #7 (permalink)
vandit's Avatar
there is no keyboard mapping software.....and the standard drivres are installed/.
vandit is offline
Old 01-07-2006, 04:11 PM   #8 (permalink)
GaurishSharma.com
gary4gar's Avatar
then try reinstall windows or reinstall service pack 2 itself
gary4gar is offline
Old 01-07-2006, 04:44 PM   #9 (permalink)
shovik's Avatar
Jguru, Vandit is talking about his Samsung keyboard not a Logitech. Try out the method which Rollercoaster suggested. Sometimes due to imporper shutdown many binaires in windows system files get chenaged and due to them we get silly errors.
Be sure that your machine is recognised by US English as most Samsung keyboard are pre-configured for that diction..
Regards,
Shovik.
shovik is offline
Old 02-09-2006, 09:41 PM   #10 (permalink)
Hey may be I know What exactly happened to ur keyboard...
see u can type as per appropriate alphabet as keyboard have...that seems ur k.b is ok as per hardware front & software front you have to select "Language layout Option" through control panel >Regional&Language option>goto Language palet>then press "detail" button & Text services & Languages applet will pop up>under settings> add or change Keyboard input language layout from US to UK (or try whatever U match) you will get proper scanning of alphabets as per you enter from your SAMSUNG keyboard. it is COZ of Samsung made these keyboards for UK users
__________
__________
Looking 4 Techno Funda
MangyaSal is offline
Old 03-09-2006, 06:12 PM   #11 (permalink)
vandit's Avatar
probs solved.... ok.....lock the thread
vandit is offline
Old 17-09-2006, 10:25 PM   #12 (permalink)
g_goyal2000's Avatar
Unhappy Re: Keyboard Problem..
Hi guys.
I have a Samsung Multimedia Keyboard (SDM4510P).
I bought it last year & it has been workinxg fine since then.
But today, while I was working, some keys on the keyboard developed a problem.
Whenever I press the left CTRL button, help files automatically open. I mean the left CTRL key is functioning like F1 key. It is not functioning like CTRL key. The F1 key is working properly.
Secondly, the right CTRL key prints "X" when I press it. It sometimes works as CTRL key. "X" key is working normally.
The third key that has developed problem is the no. 2 key (above alphabets, not numpad 2 key). It has got associated with a hotkey (User 1) on my keyboard. So, whenever I press the 2 key, the no. 2 prints but also a program associated with "User 1" hotkey runs automatically.
And lastly, the User 1 key is facing the same problem like no. 2 key.
It seems that the no. 2 & "User 1" keys have got linked & are running the same applications & printing 2 when pressed.
I have already tried all the solutions mentioned in this post. But to no avail.
Kindly help me.
g_goyal2000 is offline
Old 18-09-2006, 11:36 PM   #13 (permalink)
seems to be a prob with the internals(the contact sheets i mean)
try to get it replaced
PS u could try dropping facedown a few times on ur bed.. makes old keys work sometimes.
BTW... thanks fo reusing the thread...
Old 19-09-2006, 02:46 PM   #14 (permalink)
Well, here is the good news.
I opened up my keyboard, dismanteled everything, then put back together everything & like magic, the keybaord starts working fine.
So, here's a suggestion: If u'r keyboard develops a fault, & if u have no problem opening u'r keyboard, try to do what I did.
