Old 30-06-2006, 02:09 PM   #1 (permalink)
Thor's Avatar
Exclamation No POST ,no booting after attaching a 2nd IDE HDD
Title says it all!!
My friends PC config is :
AMD 3000+ 939 pin, MSI RS 480M2IL , 1 GB RAM, GeForce6600 GT, 120 GB Seagate Barracudda (IDE) (as Pri Master).
My HDD is Seagate 80 GB Baracudda.
As soon as I attach my HDD to My Friends PC's Primary Slave Ide Cable, It doesn't POST (or boot)!!!
even without the ide cable, only attaching the power supply cable gives the same prob. No POST!
I hv tried exchanging the power cables, ide ports (pri master, slave , 2ndary pri,slave) etc. No Luck.
Help me ?
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 30-06-2006, 02:16 PM   #2 (permalink)
Default Re: No POST ,no booting after attaching a 2nd IDE HDD
I am the friend he is talking about,,
so it concerns two DIGITomaniacs,,not 1,,
so plz pay attention...lol
arijit basu is offline
Old 30-06-2006, 02:42 PM   #3 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
There is only one apparent reason. the HDD u are adding is *SHORTING* the power rails(the 12v and 5v ones). and when there is a short circuit the SMPS switchoff to avoid damage to itself and other devices.
Rollercoaster is offline
Old 30-06-2006, 02:55 PM   #4 (permalink)
try interchanging the power cables
or check ur smps
amitgg is offline
Old 30-06-2006, 04:27 PM   #5 (permalink)
JGuru's Avatar
Either the HD is shorting the power rails, or Is the HD in good condition & working
properly? You may also check your SMPS. Regarding SMPS, what @Rollercoaster
told is true. An SMPS is an electronic power supply unit that incorporates a
switching regulator in order to stabilise the output voltage.
JGuru is offline
Old 30-06-2006, 05:17 PM   #6 (permalink)
Eazy's Avatar
If both HDDs are being attached to computer at same time make sure one is jumpered as the Master drive and the other as the Slave. Also if both HDD are being connected at same time maybe the SMPS cannot handle the extra load of the second HDD. What is the SMPS ? Have you tried connecting one drive at a time ?
Eazy is offline
Old 30-06-2006, 06:36 PM   #7 (permalink)
even that single HDD does not work,,but mine does,,but we know that the 2nd one is in perfect good condition,,at least it was ..yesterday..
and the SMPS is 400 watts colorsit..why cant it take this load?
Old 30-06-2006, 08:53 PM   #8 (permalink)
GaurishSharma.com
gary4gar's Avatar
i think u pluged wrong wire from cabinet thinking of hdd.can u post some pics of via a mobile(now days u can arrange a camera for a shot).
gary4gar is offline
Old 30-06-2006, 09:04 PM   #9 (permalink)
if there is no post(no beeps either and no video) then definately ur PSU is shorting out by the hdd.If this is true then none of ur leds,fans etc should work too.
here is what u should do. connect a multimeter to the pins of a free molex connector and watch the voltage. if u dont have a multimeter then attach two LEDS is serial between the yellow and black wire. just twist one leg of led with the alternate one of the second and insert the remaning 2 legs into the molex connector. If there is no short circuit and the PSU is fine then when u press the power button the leds will glow.
alsi see if the PSU fan switchs on or not.
Old 30-06-2006, 09:07 PM   #10 (permalink)
deathvirus_me's Avatar
did u set the jumper on the hdd properly ???
deathvirus_me is offline
Old 30-06-2006, 09:47 PM   #11 (permalink)
GaurishSharma.com
gary4gar's Avatar
this question doesnot arise because there is no post
gary4gar is offline
Old 01-07-2006, 01:22 AM   #12 (permalink)
huh ?? If he didn't put the jumper properly , there are quite some chances he won't get the to the POST ...
Old 01-07-2006, 02:44 AM   #13 (permalink)
GaurishSharma.com
gary4gar's Avatar
i have tried booting without setting jumper but it boots and rather shows up a error
gary4gar is offline
Old 01-07-2006, 09:26 AM   #14 (permalink)
what is the error.. u r alpha geek mate. if u dont explain the problem then how can it be solved.
Old 01-07-2006, 07:48 PM   #15 (permalink)
Thor's Avatar
There is NO POST . So I wonder ? Why mY HDD will Short the PSU but not arijit's ? His is 120 GB seagate , Mine 80 GB seagate ?
We have checked using Single HDD @ a time. As soon as my HDD is connected, no POST.
And yes we r connecting the correct cable. Me and arijit atleast hv this much funda : which cable to connect where. So this problem is really confusing me.
Thor is offline
Old 03-07-2006, 01:25 PM   #16 (permalink)
Thor's Avatar
Ok. Now I'am really freaked...
My Own PC, has a Sata 1 HDD (80 GB seagate) . Now when I'am connecting my HDD to my PC it not POST ing ??
Is something wrong with my 80 GB IDE HDD ?
Damn. Any Ideas Why it is happening even @ my Home PC ?
Thor is offline
Old 04-07-2006, 08:09 PM   #17 (permalink)
Thor's Avatar
Hullo? Any body ? Pls bail me out ? Will ya ?
Thor is offline
Old 06-07-2006, 09:46 PM   #18 (permalink)
there must be some wrong with ur cable or might be some compatibility prob...
