Old 28-06-2006, 01:11 PM   #1 (permalink)
Default laptop for office work
hello
i need a laptop with folowing requirements
1) wi fi
2) integrated lan
3) integrated bluetooth
4) 256 mb ram
5) 80 gb hdd prefereble sata
6) dvd writer
7) 64 bit enabled processor and mobo
8) centrino
9) gpu vista compatible
i dont want turian strictly intel,
can i get all this in a tight budget of rs 50000 ?
can someone tell me whats wifi and whats the hardware needed to make a laptop wifi
jerimski is offline
Old 28-06-2006, 01:48 PM   #2 (permalink)
MVP in VC++
Default Re: laptop for office work
For your requirement DellTM InspironTM 6400 Notebook is good and it may cost you around 50K.
And the above laptop is Wifi enabled.
cvvikram is offline
Old 28-06-2006, 02:20 PM   #3 (permalink)
tuxfan's Avatar
See, there is one thing that you can give up! Bluetooth! Dongle's are available for as low as 300 now.
2ndly, if you want your lappy to be VISTA compatible, then you need at least 512MB RAM or be ready to upgrade later at a cost. But then what happens if compatible RAM isn't available at that time? Its better to have 512 from now itself.
Goto http://www.dell.co.in. You can customise your machine. IMO Dell, Sony and HP are the brands I can trust. I have heard (and read) bad things about IBM once it became lenovo. Toshiba has some parts prob at times. And I will not even think about LG, Sahara, etc
tuxfan is offline
Old 28-06-2006, 03:17 PM   #4 (permalink)
shovik's Avatar
You can check out the following models from Acer http://www.acer.co.in/products/noteb...spire5000.html
http://www.acer.co.in/products/notebooks/tm4060.html
This models suits your budget and have every feature ecept Bluetooth which you can enable by using a Bluetooth dongle.
Wi-Fi means Wireless Fidelity, its a technology for connecting devices without wires. Presently most Laptop comes with integrated Wi-Fi, but if you have a Laptop which doesnot have this feature then you can use Wi-Fi PCMCIA cards from any brand to Wi-Fi enable your Laptop.
Regards,
Shovik.
shovik is offline
Old 28-06-2006, 04:50 PM   #5 (permalink)
JGuru's Avatar
You can go for Acer or HP Laptop. You can get the latest prices from the dealer in
your city.
JGuru is offline
Old 28-06-2006, 06:47 PM   #6 (permalink)
thank u all guys for ur kind response,
id like to know that are viao laptops from sony more expensive than the other brands, and
i dont know anything about pcs or laptops but people say that acer has a flimsy screen and dell has really bad serivce network so please which one would u recomend to me
if u can name a model il be gratefull guys and yeah price too
thank u all for ur kind response im really gratefull
jerimski is offline
Old 30-06-2006, 12:16 PM   #7 (permalink)
tuxfan's Avatar
I am using a VAIO They may seem expensive, but its the quality that matters My VAIO is only 1.7kg with battery and battery has a life of 6 hrs!! Of course I paid a bomb for it, but its truly great!! I am really happy with it. I don't consider myself a techie, but a few techie friends are also using VAIO and are happy. My brother is using Dell and is happy too! So its ultimately, value for money that matters.
But for lappies, the first thing that you should do is fix your budget. You've already done that.
Then in that price range check the specs, warranty, extended warranty, weight, battery life, service center, etc. and then buy.
In specs you must check
1. Processor
2. MoBo
3. RAM (how much, how many sticks, upgrade cost)
4. HD
5. Optical Drive (DVD RW, Combo, etc.)
6. Screen size
7. Keys of the keyboard. Check if you are comfortable with the size of keys
8. Goodies like fingerprint sensor, webcam, etc.
9. Wi-Fi
10. Card Reader, bluetooth
11. Whether extra monitor can be attached to it
12. Type of graphics card
13. Number of USB ports (not too imp)
etc.
I have an excel sheet that I got from one dealer when I was inquiring for a lappy for me. Its about 1-2 months old. PM your email address and I will mail that sheet to you
tuxfan is offline
Old 30-06-2006, 12:49 PM   #8 (permalink)
my email id is
jerimski@yahoo.com , thank u for ur reply please send that sheet n yeah how much does viao costs ?
jerimski is offline
Old 30-06-2006, 05:45 PM   #9 (permalink)
tuxfan's Avatar
Sent by email
tuxfan is offline
Old 14-08-2006, 08:09 PM   #10 (permalink)
hey there
can u send tht list to me tooo ..i want a lappy but i have a very tight budget around 40 k
hey there
agm105@30gigs.com
agm_1052001 is offline
Old 15-08-2006, 11:53 AM   #11 (permalink)
tuxfan's Avatar
I am sorry I have deleted the sheet.
tuxfan is offline
