Old 27-06-2006, 10:54 PM   #1 (permalink)
pop143's Avatar
Wink RAM -moherboard-burn
hi
my friend got a 512mb ddr ram himself and installed in his HCL beanstalk motherboard...it got smoked up and now they say mobo repair,
they say ..u shud put only hcl company ram..wot they mean..?
btw do it is highly necessary...ram shud be bought on the basis of that cpu mhz speed thing..? or else is is it a problem making?
wots th theory in these ram , cpu speed? etc....cud u please tell.in detaill...!!
pop143 is offline
Old 27-06-2006, 11:08 PM   #2 (permalink)
ashfame's Avatar
Default Re: RAM -moherboard-burn
go here:
http://forumz.tomshardware.com/hardw...pict55024.html
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 28-06-2006, 01:21 AM   #3 (permalink)
shovik's Avatar
The RAM module you r installing should be in compliance with your mobo memory controller's frequency. Otherwise there is a chance of burnout.
CPU frequency has nothing to do with RAM frequency. So check your mobos manual or your hardware vendor to install the current RAM module.
Regards,
Shovik.
shovik is offline
