Old 27-06-2006, 06:51 PM   #1 (permalink)
ArZuNeOs's Avatar
Default Mobo for D 930 ...help!!!!
Guys i am planning to buy a D 930 Proc
I need a mobo Wid onboard Sound...VGA...Lan...& common items
my budget is 5k..can extend upto 5.5k
Help needed
Back to the world of realms
ArZuNeOs is offline
Old 27-06-2006, 09:17 PM   #2 (permalink)
deathvirus_me's Avatar
Default Re: Mobo for D 930 ...help!!!!
Well .. any 945 chipset based board should do a good job ....
deathvirus_me is offline
Old 27-06-2006, 09:46 PM   #3 (permalink)
samrulez's Avatar
Well ASUS 945 PL is a good mobo....but i'm not too sure if it is available easily......but any 945 based mobo will do...for the brand ASUS is prefered..
Sam :D Rulez :lol:
samrulez is offline
Old 28-06-2006, 01:41 AM   #4 (permalink)
shovik's Avatar
Go for Intel Desktop Board D945GRW board which is the best combo with the D 930 processor. Also there are cheap solutions from Intel in the form of Intel Desktop Board D101GGC and Intel Desktop Board D102GGC2. The latter mentioned mobos come at price range of Rs.3,800-Rs.4,200.
Regards,
Shovik.
shovik is offline
Old 28-06-2006, 05:43 AM   #5 (permalink)
ArZuNeOs's Avatar
Shovik
Thanks
Can U plz point out the advantage of GRW & D 101GGC respectively
are there any differences in performace & some built in materials...stuff like ports
ArZuNeOs is offline
Old 28-06-2006, 11:24 PM   #6 (permalink)
dissel's Avatar
hi,
I have D 940 running on D945GNT Mobo......But it seems that is not justified with Intel D940 .....
Only D945GPM is prpoer selection for these Hot Babe.
coz it have onboard support Intel® Viiv™ Technology and much more.
See http://www.intel.com/products/mother...5gpm/index.htm
I recomend this for your processor.
Don't go with D101GGC.....
I don't think the the D101GGC or D102GGC2 have dual core processing mode.
they only support and install Dual core Processor but not the processing.
See here :http://www.intel.com/products/mother...1ggc/index.htm
See herehttp://www.intel.com/products/mother...ggc2/index.htm
The main diffrence between D101GGC and D102GGC2 is that D102 suports DDR2 Ram.....but not the dual channel mode.
But any Intel® 945G Express serries suports dual channel memory.
and dual core processing.
D945GTP and D945GNT are eassily available any where.
See herehttp://www.intel.com/products/mother...5gtp/index.htm
See herehttp://www.intel.com/products/mother...5gnt/index.htm
Only diffrence between the two is GTP is Micro Atx and GNT is ATX.
dissel is offline
Old 29-06-2006, 10:19 AM   #7 (permalink)
yogi7272's Avatar
go for any one of these gigabyte mobos ..
http://www.gigabyte.com.tw/Products/...Name=GA-8I945G
OR
http://www.gigabyte.com.tw/Products/...A-8I945G%20Pro
yogi7272 is offline
