Old 27-06-2006, 09:39 AM   #1 (permalink)
Chillum Baba
a_medico's Avatar
Question USB 2.0 query
How do we know whether a pc has usb 1.0 or 2.0?
How to convert usb 1 to usb 2? is there any external converter available?
Approximate cost?
thanks.
a_medico is offline
Old 27-06-2006, 02:16 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: USB 2.0 query
The main board comes equipped with USB controllers. So it depends on the chipset and its specifications. If its a new system purchased in the last couple of years, it would most probably be a USB 2.0
USB 1.1 cannot be converted into USB 2 just like that. You would have to add a PCI slot offering you 2-4 USB ports at the rear of the cabinet or probably a IDE device fitting on the front disk bays on the cabinet. Not quite sure about the availability of the latter.
Approx cost for the PCI card would be around 1k. For accurate prices, refer ebay.in
Sourabh is offline
Old 27-06-2006, 04:43 PM   #3 (permalink)
ashfame's Avatar
usb2.0 will work as usb1.1 if drivers for it r not installed
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
