26-06-2006, 10:18 PM
about pentium d 805 *
FSB of pentium d 805 is 533mhz so ddr2 ram of >533mhz will work as only 533mhz
and ddr2 533mhz ram r slower than ddr 400mhz?
so for d 805, should i opt for a board with ddr 400mhz support?
help...
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
26-06-2006, 11:21 PM
Re: about pentium d 805 *
help...
i never knew that FSB and RAM clocks were related
DDr2 533 Mhz is much faster than than DDR 400, but the previous has much higher latencies as well. If u afford a low latency mem., its gr8
~"Computers are useless. They can only give you answers."~
27-06-2006, 04:36 AM
Then u better do some study .. them damm sure are. ..
Well .. the cheap one's are . coz they have uber high timings ... at stock with a similar processor , the ddr400 should do better ... but hey ... 100 MBps matter much ???
27-06-2006, 04:53 PM
how much more do lower latencies ram cost?
i can get 512mb ddr2 533mhz @ rs.1750!
how to recognize lower latencies ram ?
27-06-2006, 05:06 PM
Usually there is a sticker on the module.But alternatively u can use s\w like CPU-z etc.
DDR1 modules usually have a rating of 2.5.....
Sam :D Rulez :lol:
27-06-2006, 05:27 PM
DDR1 modules usually have a rating of 2.....
how can i use s/w when i am buying it?
and wht is on the sticker?
27-06-2006, 05:31 PM
I mean that there is a lable on the module that has the info.i.e speed,size,latency etc.
Sam :D Rulez :lol:
27-06-2006, 05:40 PM
so lower latency of 512 ddr2 533mhz. will be .......
27-06-2006, 08:55 PM
RAM LATENCY
DDR2(low latency) vs DDR (includes names of mems)
Mostly, Corsair and Kingston manufacter these low latency mem modules.
This should help
27-06-2006, 09:05 PM
Well consider this .. normal ddr400 from zion with latencies 3,3,3,6 costs in at about 4600 bucks for 1 GB ... now consider ddr400 OCZ gold edition modules with latencies at 2,3,2,5 which costs in at 10500 for 1 GB .... not much diff. eeh ??
27-06-2006, 09:56 PM
oops!
does intel 945 mobo supports > 533mhz ddr2 ram?
27-06-2006, 11:44 PM
help...
Consider overclocking by increasing the FSB.
PD805 overclocks easy.
28-06-2006, 11:02 AM
PD805 is the current oc king .. upto 3.8 -3.9 on air .. and 4.2 -4.4 on water ..
also intel 945 chipset does support ddr2 667 ...
