Old 26-06-2006, 09:21 AM   #1 (permalink)
The cake is a lie!!!
iNFiNiTE's Avatar
Default Help : Laptop Purchase
Hi there , I am about to buy a laptop but i havent been able to decide a brand/model. Can somebody suggest me a decent brand/model. My budget is about 60,000/-. How about Lenovo's 3000 N series. What if i want to get extra/optional devices in the given models. For ex 512 Ram instead of 256 or DVD writer instead of a combo.
Please advice.
Also can you also tell me what extra accessories are tob purchased and options/ features to be looked for.
"Some things Man was never meant to know. For everything else, there's Google."
iNFiNiTE is offline
Old 26-06-2006, 01:42 PM   #2 (permalink)
MVP in VC++
Default Re: Help : Laptop Purchase
You can go for the Lenovo model '3000 N100' which you can customise further to u r needs.
or
look for Dell TM LatitudeTM D520 Notebook, which also suits your budget....
Both r good.....
cvvikram is offline
Old 27-06-2006, 01:08 PM   #3 (permalink)
tuxfan's Avatar
I will suggest go for a Dell. Altough I have had issues with support in the past, but as on today, that looks to be the best alternative for your budget.
Additionally, it will let you customise what you want. So you get the real punch for your money
tuxfan is offline
Old 29-06-2006, 05:54 PM   #4 (permalink)
iNFiNiTE's Avatar
Thanks for you help.
iNFiNiTE is offline
Old 29-06-2006, 06:17 PM   #5 (permalink)
shovik's Avatar
Yeah with a budget of 60,000 you should go for a Dell.
Regards,
Shovik.
shovik is offline
Old 29-06-2006, 06:27 PM   #6 (permalink)
Resident Weapons Expert
zombie's Avatar
Go for Dell with your eyes closed. Though my choice would have been IBM if you had asked me 2 years back. But now its Lenovo and I dont trust the quality.
Stalk, Strike, Survive.
zombie is offline
Old 29-06-2006, 06:30 PM   #7 (permalink)
shovik's Avatar
You can also try out the latest Lenovo 3000 N100(model no.06895KA).
Check out the configuration here:
http://www-604.ibm.com/webapp/wcs/st...catalogId=-356
Also you can customise according to your needs, but don't think that with a configuration the N100 offers you won't need any currently.
The second option is as always Dell as I have mentioned. You can try Dell XPS M1210 Inte Core Duo T2300 Notebook at:
http://dellstore04.sg.dell.com/publi...=38741&sr_no=2
i hope that these two machines would help you in deciding about your purchase.
Regards,
Shovik.
shovik is offline
