Re: auto wht??
Firstly check your system for potential viruses and spyware software.
I don't think this is a heat issue, because ...when you r working on the pc then there is more load as compared to when it's idle.
Also check the power settings in the control panel, there can be a problem when system goes into sleep mode (by default it's 20min) because of missing or corrupt motherboard drivers so update them. Try and disable sleep/hibernation and see if the problem persists.
AMD Athlon64 2800+, MSI K8N Neo3(NForce4), 1GB Kingston DDR400, MSI Geforce 7600GT PCIe, Viewsonic VA702b 17" LCD, Creative SB Live! 5.1, Logitech Z-5300 5.1 THX Speakers, Seagate 200GB SATA HDD
