Old 24-06-2006, 08:46 AM   #1 (permalink)
Default strange problem
Hi all,
I am having intel 865gv mobo + p IV 2.8 ht + 512 DDR RAM + 410 GB HDD ( 250+160+20). For last 2 months I am facing one problem. When I keep my PC on for long time ( say overnight) unattended and then try to switch on the monitor, the LED keeps on blinking and nothing appears on monitor though the CPU seems to keep on working. later on I checked my internet download status( as I was downloading some movie in night, just to check if CPU was working or not) and it showed that even download had stuck 3 hrs back!!!!!... can anyone suggest the possible cause/remedies???
thanks in anticipation....
Abhishek
abhi99_iitg is offline
Old 24-06-2006, 08:52 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: strange problem
Looks like your PC goes into standby mode and becomes unresponsive there-on? Check your power settings if any option ia available to stop standby and just close monitor in turn.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 24-06-2006, 12:06 PM   #3 (permalink)
Official Techie's Avatar
just go to control panel-->system and then power options there u will see power schemes use the always on scheme
Game Khelwanu Magazine Padhwanu Majjani Life
http://sudiptatech.blogspot.com/
http://sudiptamondal.blogspot.com/
Official Techie is offline
