Originally Posted by Wannabe_a_techie
Thanks guys but I don't need the CDs...just wanted to know what is the damage if I can't see any marks?
First of all, as pop143 quite rightly suggested, it may be a problem with your drive. Sometimes drives work fine with most CDs but take exception to some. Try them on a friend's PC.
And it is not necessary that there will always be physical signs when a disk is damaged. I have many CDs that are scarred worse than a tree trunk but do the job just fine and others which the drives fail to read even though it looks perfectly innocent.
It may be that the burning software or the drive used messed something up and the CD turned out to be faulty. There may be some other sort of software damage.
