Re: usb problems
Connect it properly for the Falsh pen drive to work. Even a slightly loose connection, which may seem as if it's connected properly, your pen drive won't work. I have seen his happening a number of times with my USB DSL modem. You can try connecting it at your friend's place to see if it works. Sometimes it may even be damaged. So check all the options.
Reason: The sentence not formatted well enough
