Old 23-06-2006, 02:28 PM   #1 (permalink)
Manchester United
abhijit_reddevil's Avatar
Question Good cabinet within Rs.3000
Hi friends,
My 3 1/2 year old cabinet is showing signs of retirement and also not able to ventilate the system properly. So some of the components are getting heated up. So I thought I would buy a good cabinet with at least 2-3 cooling fans (maybe 80mm or 120mm). The cooling fans part is important. So what do you recommend? My budget is around Rs.3000, maybe stretched to Rs.3500 and NOT MORE.
I have shortlisted some although I have no idea about the price. They are Antec SLK 1650B, SLK 3000B and VIP G300. Can you the prices of these? Or any other recommendations?
Please help.
Thanks.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 23-06-2006, 05:58 PM   #2 (permalink)
shovik's Avatar
Default Re: Good cabinet within Rs.3000
Go for the Workhorse model from i-Ball. Its definitely worth the price.
http://www.enteriworld.com/product.a...e=Work%20Horse
Regards,
Shovik.
shovik is offline
Old 23-06-2006, 07:35 PM   #3 (permalink)
The Frozen Nova
casanova's Avatar
I second iball workhorse. Full metalic body, good ventilation costs 2k. So u have additinal 1k to add extra ventilation/moding... whatever u prefer.
www.nerdweed.blogspot.com
casanova is offline
Old 23-06-2006, 09:46 PM   #4 (permalink)
samrulez's Avatar
Since u have money remaining...mod the case...add loads of lightings!!..
And add xtra cooling fans..
Sam :D Rulez :lol:
samrulez is offline
Old 23-06-2006, 11:40 PM   #5 (permalink)
dOm1naTOr's Avatar
Consider Zebronics Antibiotic cab. It can be bought around 2.2knd has tons of features.
3 LED fans bundled.
LCD temp display on front.
Transparent side panel.
Good cooling architecture.
Good build Quality.
A blowhole at the top.(the fan starts only when its opened)
400w PSU bundled.
Good case for other moddings nd lightings.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 24-06-2006, 12:49 AM   #6 (permalink)
JGuru's Avatar
Yeah Zebronics Antibiotic cabinet is pretty good. You can give it a try.
JGuru is offline
Old 24-06-2006, 01:46 AM   #7 (permalink)
The Hardware Labs
mohit's Avatar
stretch ur budget to 3.5k and buy the Zebronics Jamaica ..ull never regret it ... its same as VIP ZB-01 with front usb n firewire .. very very huge cabby with excellent ventilation n space.
its basically a server cabby but many people including me use it for our desktops.
mohit is offline
Old 24-06-2006, 02:01 AM   #8 (permalink)
shovik's Avatar
But still iBall Workhorse fits everybodys bill and is also easily available. Zebronics Cabinets are no doubt good but their availability and just a few led fans don't make them worth considering.
Regards,
Shovik.
shovik is offline
Old 24-06-2006, 02:23 PM   #9 (permalink)
The Hardware Labs
mohit's Avatar
zebronics cabinets are available all over india ..and u can also buy directly from zebronics if they are not available at ur place ..and jamaica does not have any led fans ..its a plain looking sturdy n roomy cabby. check it out..
mohit is offline
