Old 23-06-2006, 02:01 AM   #1 (permalink)
speedyguy's Avatar
Default USB Hub Installation Problem
im trying to install a usb hub 1*4 device....its a completely plugn play device....but wen i plug in any usb device just one at a time works....
for eg. i 1stly plugged in my usb gamepad...it worked...then plugged in my usb pen drive....now both of em not working....
when i release usb gamepad....my thumb drive gets connected....so its like just one usb device is working.....though there r 4 ports...ne idea ne1...
ps: my system is p4 i845GV w/ usb 2.0 (2 ports)
one port is used up by this hub n other by mobile data cable (connected)...
thanx
cheers
No Pain...No Gain
speedyguy is offline
Old 23-06-2006, 02:21 AM   #2 (permalink)
shovik's Avatar
Default Re: USB Hub Installation Problem
Try to plug in two devices into alternate USB ports of ur Hub, even then if it is not working then then the internel USB circuitry of ur HUB is faulty which makes it work on 1 channel only.
Try to get it check with some of ur friend, if it works with ur friend then the problem seems to be with ur USB Hub controller drivers of ur OS but if not then try to get it replaced.
Regards,
Shovik.
shovik is offline
Old 23-06-2006, 12:12 PM   #3 (permalink)
speedyguy's Avatar
ive already tried 1 ast one.....its d same....i wud get it checked if theres som problem wit d hub.....
do i have 2 install any drivers for it seperately....i mean i dun find anythin on hardware devices n neither there r increased no of ports
thanx
cheers
No Pain...No Gain
Old 25-06-2006, 06:37 PM   #4 (permalink)
speedyguy's Avatar
well i just went back there....dunno wats going wrong.....they have every set n all workin like same...vendors sayin i shudnt plug higher capacity devices....but still its d same...only 1 at a time
do i have 2 install seperate drivers for ths hub coz theres no change in device manager wen i plug it in...
cheers
No Pain...No Gain
Old 25-06-2006, 11:34 PM   #5 (permalink)
godsownman's Avatar
cheers
No additional drivers required. However what I'd request you to do is to try it at a friends place. Sometimes the OS creates a problem which no one can figure out.
Hope this helps.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 26-06-2006, 12:47 AM   #6 (permalink)
speedyguy's Avatar
unfortunately its d same everywhere....tried it....any other advice
cheers
No Pain...No Gain
