Old 22-06-2006, 08:27 PM   #1 (permalink)
Default Pc100 Sd Ram
Hi,
I need to add RAM to the 5-yr-old PC that I use for surfing the Net.
Config:
HP Brio BAx
P3 600 Mhz
64 Mb SDRAM
8.4 Gb HDD
Matrox MGA G200 graphics
How much shold i pay for 64Mb/124Mb/256Mb SDRAM? Second hand or otherwise?
Can someone give me an idea??
naru is offline
Old 22-06-2006, 09:26 PM   #2 (permalink)
\/endett/\'s Avatar
Default Re: Pc100 Sd Ram
256 mb sdram @ 100 mhz is approx Rs. 1600 {hynix}
Check ebay.in for more details.
~"Computers are useless. They can only give you answers."~
\/endett/\ is offline
Old 23-06-2006, 09:42 PM   #3 (permalink)
GeekyBoy's Avatar
My advice for you:Upgrade your current RIG!!
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 24-06-2006, 12:55 AM   #4 (permalink)
JGuru's Avatar
I don't think you can get the RAM for your PC. You need to upgrade!!.
JGuru is offline
Old 24-06-2006, 09:37 AM   #5 (permalink)
You should be able to get 256 Mb sd ram for 1300 bucks
cyrux is offline
Old 24-06-2006, 05:48 PM   #6 (permalink)
ashfame's Avatar
u can get
64mb @ CAN't FIND THEM
128mb @ rs.750
256mb @ rs.1500
no need to upgrade ur pc much.
if u use pc for browsing then it will just do with more ram.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
