Old 22-06-2006, 07:53 PM   #1 (permalink)
Default Help with speaker Selection
I want to purchase speakers.my budget is 6K.
should i go for 2.1 or 5.1 speakers?
my main usage is music with soemtimes games and movies.also we do not
get much of original dvds over here (too costly for me to buy) on rent.
So please suggest me the speakers with price in 2.1 and 5.1 range.
thanks.
Digital_Paladin_ is offline
Old 22-06-2006, 10:43 PM   #2 (permalink)
pedal to metal
suave_guy's Avatar
Default Re: Help with speaker Selection
for ur budget...
if you want 5.1 speakers than i'll suggest logitech x-530
http://www.logitech.com/index.cfm/pr...CONTENTID=9067
if you want 2.1 speakers than go for altec lansing CS21
http://alteclansing.com/product_deta...ountry_code=in
ENjoy...
your "attitude" is your best friend...
suave_guy is offline
Old 23-06-2006, 07:42 AM   #3 (permalink)
watz the cost baby
chota_rod_waala is offline
Old 23-06-2006, 09:05 AM   #4 (permalink)
MVP in VC++
If you want 2.1 then Altec ATP3 is best....you can get it for around 2500/- to 2700/-
cvvikram is offline
Old 23-06-2006, 10:51 AM   #5 (permalink)
what is the price of logitech x-530 and altec lansing CS21?
Old 23-06-2006, 11:22 AM   #6 (permalink)
MVP in VC++
The price of Logitech X-530 is around 6500/- and X-230 is around 3500/-
Whereas altec lansing CS21 costs you around 6500/-
cvvikram is offline
Old 23-06-2006, 01:03 PM   #7 (permalink)
pedal to metal
suave_guy's Avatar
well, digital_paladin as u said in ur earlier post that music is ur main priority therefore you can go for 2.1 speakers and altec lansing CS21 gives amazing music performance and is best suited for ur budget wherears if you want to go for lower budget speakers than as cvvikram said, u can go for altec ATP3, they are the best speakers available below 3K
on the other hand logitech x-530 is an above average 5.1 speaker set and cannot match altec lansing cs21 in terms of bass and sound depth....the truth is that there are no 5.1 speaker sets below 10K which we can consider as a good performer though you will definately get average performing speakers like logitech x-530, creative inspire 5.1, altec lansing vs3151(which i guess is discontinued now), so the fact is that there's no point in going for these kind of speakers as they dont offer too much in terms of audio quality...
the cheapest 5.1 set which i consider as a good performer and offers good audio quality is logitech Z-5300 which is available for arnd 11-12K
so if you want multichannel sound and there's a scope for the expansion of budget than go for these speakers otherwise stick with your current budget and go for altec lansing CS21...
ENjoy...
