Old 22-06-2006, 05:50 PM   #1 (permalink)
Exclamation Need Help on Cyrrix Processors
Hi,
I just brought a cyrix processor last week, but everytime i try to run media files(avi, rm, wma, wmv, mp3) on it, it gives me an Error saying the application terminated. But it runs the media files sometimes, sometimes not.
Is it not compatible?
The config is Cyrix 1GHz, 128mb ram, 40GBhdd..
manishjj is offline
Old 22-06-2006, 11:09 PM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: Need Help on Cyrrix Processors
Must be a driver problem or codec. Please update ur driver and install K-lite codec pack. So if possible please give the full pc config. and details of error.
And what do u mean by "it is not compatible"?
john_the_ultimate is offline
Old 23-06-2006, 04:18 PM   #3 (permalink)
Geforce's Avatar
I think ... Cyrix proccies are fully x86 compatible.
Update the motherboard (chipset) drivers and the display drivers. Some videos codecs use hardware acceleration so drivers are critical.
AMD Athlon64 2800+, MSI K8N Neo3(NForce4), 1GB Kingston DDR400, MSI Geforce 7600GT PCIe, Viewsonic VA702b 17" LCD, Creative SB Live! 5.1, Logitech Z-5300 5.1 THX Speakers, Seagate 200GB SATA HDD
Geforce is offline
