Old 21-06-2006, 07:32 AM   #1 (permalink)
Default Speaker Mic conflict?
hi,
I have 2.8Ghz , 512 MB ram , Intel 915GAV , LG CD Writer , 80GB HD , Win XP SP2 , every patch applied.
Recentl i got my windows reinstalled , It is a dual boot Win 2000 serv. and Win XP ,
Problem::-- Whenever i try to use any software or messenger using Mic , it shows up a blue screen , Givin error
IRQL_NOT_LESS_OR_EQUAL
and then all that k if this problem persists then contac blah blah .
Please let me know how to cure this prob.
Thanx
navisangha is offline
Old 21-06-2006, 04:44 PM   #2 (permalink)
Default Re: Speaker Mic conflict?
plz help me out.
Thanks
Old 21-06-2006, 11:31 PM   #3 (permalink)
moshel's Avatar
when i had that problem, it turned out that my ram was corrupted. i replaced the ram and everything worked fine. so do check ur pc by removing the ram that u have and placing another one
moshel is offline
