Old 21-06-2006, 07:16 AM   #1 (permalink)
nach p's Avatar
Exclamation Via chipset or Intel Original
Hi guys,
I am going to buy a new PC.I have some queries regarding mobo and processor.
Which motherboard should I select between Via chipset or Intel original and if possible then model no.and also supporting processors to that mobo.
Thnx in advance!!
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 21-06-2006, 07:26 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: Via chipset or Intel Original
Umm not much idea about model no, but definately go for intel original. Via is utter crap. Go for nvidia chipset if you cannot get intel original.
kalpik is offline
Old 21-06-2006, 07:30 AM   #3 (permalink)
i have via chipset its crappp or what every u like to say its waste ! dont even think of buying it .
i
hermit is offline
Old 21-06-2006, 08:10 AM   #4 (permalink)
via doesnt give the full performance
intel ok average
get nvidia chipset runs cool
go with AMD AND MSI
chota_rod_waala is offline
Old 21-06-2006, 08:20 AM   #5 (permalink)
gxsaurav
Posts: n/a
vis is good, but only i u keep up with the driver updates
Old 21-06-2006, 11:07 AM   #6 (permalink)
gsmsikar's Avatar
via is good , i dont think there is any problem with via , but yeah u have to keep the drivers update and it also have many other features which are not available with intel boards ...
gsmsikar is offline
Old 21-06-2006, 12:57 PM   #7 (permalink)
samrulez's Avatar
Well for a AMD based comp get a mobo with nforce4...
Intel original is good for intel processors...
VIA is cr@p.....
As for the brand stick with ASUS...
Sam :D Rulez :lol:
samrulez is offline
Old 21-06-2006, 04:20 PM   #8 (permalink)
nach p's Avatar
I think I should go for Intel Original.
Now I have one more question regarding Ram!!
What is preferable ? i.e.one 1gb stick or two 512mb stick.
Which option will give better performance?
-Dennis Ritchie
nach p is offline
Old 21-06-2006, 07:21 PM   #9 (permalink)
Angry Re: Via chipset or Intel Original
VIA is cr@p.....
via is not crap
its just below intel by 10%
Old 21-06-2006, 07:25 PM   #10 (permalink)
samrulez's Avatar
Go for 512 X2 sticks and put it in dual channel mode so it will double up the speeds...Put it in the ram slots of the same colour...and it will be done..
Sam :D Rulez :lol:
samrulez is offline
Old 21-06-2006, 07:29 PM   #11 (permalink)
Thumbs down Re: Via chipset or Intel Original
yup dual channel wimm make game loading times small
but dont expect any fps change with dual channel
and the general perforamce like windows will be doubled practically but expect 50% increase atleast in real time.
Old 21-06-2006, 07:29 PM   #12 (permalink)
ashfame's Avatar
two sticks of 512mb will cost u less & they can be used in dual channel mode (if ur mobo supports it) for performance boost
EDIT:
Sorry for answering again but last time page was loaded upto ur ques & not upto where ur ques was already answered.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 21-06-2006, 10:59 PM   #13 (permalink)
deathvirus_me's Avatar
Well ... VIA is better than intel original anytime ... i ran my 2400+ on a VIA chipset and loved the performance .....
deathvirus_me is offline
Old 19-07-2006, 07:24 AM   #14 (permalink)
nach p's Avatar
Finally I bought P D 2.8 and D945GNTL and Transcend 1 gb ddr.
I dont play high end games so above cofig must be fine for me.
Thnx for replies.
-Dennis Ritchie
nach p is offline
