Originally Posted by digitized
Hi,
I am facing a weird problem (actually I do not know whether this is classified as a problem). Please see the signature for my complete machine specifications. The fan of my 3000+ CPU is making considerable amount of noise after about an hour of usage. I have overclocked my CPU from 1.8Ghz to 2.25Ghz. I have been using this o/c'ed system for the past 2-3 months without any problem. I have double checked my system and confirmed that the noise is indeed coming from the CPU fan and not from my graphics card.
Is there any way that I can reduce the fan noise? Enabling cool and queit may be an option but I am not so sure. I had to disable it in order to run my overclocking experiment successfully. Enabling it and restarting always resets to the default system specs. It may also be that the fan has become defective and may need to be replaced but that too I am not too sure. Moreover since I o/ced my system and also updated the Asus BIOS to latest (ver 1011), I may have lost warranty coverage.
Please help!
First of all why should you lose the warranty because of Bios update. Asus update is provided with your Mobo SW and it is obtained from their website.
I have a more or less similar configuration but not overclocked, but I have updated Bios 3 times to the present V.1013.
Reg. the CPU fan noise, if Cool&Quiet is disabled, it is somewhat noisy. The RPM is bound to be >5000. To it add the noise from the chipset fan of A8N-E which in my case runs at >5000 even when Cool&Quiet is enabled whereas CPU fan speed ranges between 1000 to 3000.
May be because you have overclocked and the fan has been running continuously for long at high speeds, the sleave/bearing has become damaged. But make sure about it before replacing. And I doubt whether you will get a genuine fan.
