Old 18-06-2006, 06:44 PM   #1 (permalink)
samrulez's Avatar
Default Help with MOD................
Ok...I want to mod my cabinet.I want to cut the side panel.Can u tell me how do i cut it?Which tool to use?Will the final finish be good?Should I do it?
Sam :D Rulez :lol:
samrulez is offline
Old 18-06-2006, 11:43 PM   #2 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default Re: Help with MOD................
check this thread out My CASE MOD --- Reviewed SEE it yourself!!
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 19-06-2006, 07:23 AM   #3 (permalink)
thetopcyborg's Avatar
just take it to a garage shop and they'ss cut it fer u
thetopcyborg is offline
Old 19-06-2006, 10:00 PM   #4 (permalink)
samrulez's Avatar
No my question is that will I have to re paint it?Is it possible just to cut the side panel without painting anything???
Sam :D Rulez :lol:
samrulez is offline
