Originally Posted by ashfame
but he already has a 512mb stick so to make it to 2gb its better it go the way i told so that no future upgradation problem is faced by him
He may better try to exchange the ram with the dealer when buying the new 2X1GB. This is what I am going to do. (I have 2X512). This way it is easier to ensure that the rams are identical. Also I doubt whether he can run 2 rams in dual channel and one in single channel.
Or else he can try to sell the 512 MB before buying the new ones.
Furhter, earlier there used to be a problem that if you fill more than 2 slots with 400 MHz ram they will run @ 333 MHz. (In case of Nforce 4) About Intel, I dont know, and whether such problem is there with current Mobos.
