Old 17-06-2006, 08:30 AM   #1 (permalink)
Default Should I sell my A8N SLI Deluxe
Hi all.......
I have an A8N SLI Deluxe board. I bought this board when I was a computer enthusiast.....but now the comp is in my office.
Unfortunately the board gets into chipset fan trouble evry 3-4 months. The comp is main server and 5 clients are attached to it. Its really a big problem disconnecting the comp and taking it to the vendor and getting the fan changed very 3-4 months. I have talked to my vendor and he is ready to exchange it for another board.
I bought this board around Jan 2005 and except for the fan the board is a baby
My questions are
1 Should I sell this board and get a new one
2 If the answer to 1 Is yes then what price should I expect from my
vendor
3 Last but not the least, if i do sell this board which board should i
get. I need a no frill but High Performance board which should
come within the sale proceeds of the SLI (Maybe a little extra)
4 I am from chandigarh and if anyone of u is interested in buying
this board do pm me
Hope u will sort my confusion out
[url]http://www.danasoft.com/sig/cool_cool_cool.jpg[url]
geek is offline
Old 17-06-2006, 09:09 AM   #2 (permalink)
Default Re: Should I sell my A8N SLI Deluxe
The early editions of the board did have issues with the northbridge fan. I suggest you get Asus to replace the board. If it dosen't work out you could sell it and get a Asus A8N-E which is basically the same board minus the SLI.
As far as buying from you is concerned, why would anyone buy a motherboard they know is defective?
drvarunmehta is offline
Old 17-06-2006, 04:01 PM   #3 (permalink)
thetopcyborg's Avatar
HEy, Im buying a A8N-SLI (new) in a few days, shud i go for it or no? has the problem been rectified now?
thetopcyborg is offline
Old 17-06-2006, 11:13 PM   #4 (permalink)
TechGuru#1's Avatar
Wink Re: Should I sell my A8N SLI Deluxe
Yeah fikar not yaar!
The Recent Bios updates have all the fixes.
anyway, me on my A8N SLI Premium running perfectly stable!
TechGuru#1 is offline
Old 18-06-2006, 06:59 AM   #5 (permalink)
The pWnster
Vyasram's Avatar
Me had chipset fan troubles with a8n-e , ask asus, they'll put a bigger and better fan on ur mobo.
Sigs suck
Vyasram is offline
Old 18-06-2006, 12:34 PM   #6 (permalink)
does it have onboard graphics?
Old 18-06-2006, 01:16 PM   #7 (permalink)
No
Old 18-06-2006, 01:40 PM   #8 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
get a A8N Sli premium.. it heatpipes to cool chipset so....
No Chipset Fan.. No Problem
BTW i have one and it is super kool
Rollercoaster is offline
Old 18-06-2006, 01:46 PM   #9 (permalink)
deathvirus_me's Avatar
Well .. u can contact the Asus dealers .. they should send in a replacement fan (a lot better) ... that should solve the problem .. also update the bios to ramove any kind of hardware conflict ....
deathvirus_me is offline
