| Forum |
#1 (permalink) |
I Always Prefer 1080p
does anybody else experience this problem |
#3 (permalink) |
the download speeds i get with azureus and bitcomet are about 25-30kbps, but they download for about one hour and then the modem just freeze.
also could this problem be due to the fact that bittorrent requires good upload speeds and BSNL has only a max upload speed of 64kbps and download speed of 256kbps i have set my upload speed to be auto configured by azureus and it has set my download speed as unlimited but upload is restricted to 25 kbps. the same problem is happening with bitcomet too also when i use limewire pro v 4.8.1 i can download continuosly for about 16 hours and my modem doesn't freeze and download speed is about 35 kbps and upload is about 16 kbps also the TCP reachability is ok with both the torrent clients so i know that this is not a FIREWALL problem |
#8 (permalink) | |
dont use azureus its crap insted use utorrent.com believe me its very small in size and very effective Last edited by blackcobra; 16-06-2006 at 03:06 PM. |
#9 (permalink) |
yesterday i used rapidshare to download an entire movie, but had no probs, when i use torrent i cant download for more than half to one hour. the problem is definitely with torrent, but i dont know whether the problem is with the client or protocol itself. also am not banned or something with torrent client programs
#10 (permalink) | |
Manchester United
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen
#11 (permalink) |
i have correctly forwarded the ports coz, azureus is showing that TCP/IP status is ok and its in green . if there is a config problem, then the icon would be in yellow or white. also the distributed user tracking program also works properly, so
1. if my modem is not working as some have suggested, then how am i able to download continuously using rapid share(premium account) using download accelerator plus 2. i have tried torrent clients bittorent, azureus and bittornado. 3. i use J2RE 1.5.0.10. could this be corrupt ? 4. my firewall is configured to allow both incoming and outgoing connections and protocols for azureus so what else is the problem My Sys config INTEL 915 GAV p IV 3.2 Ghz 2*512 MB DDR Ram XFX 6200 nVIDIA Card with latest driver updates Windows XP SP 2 Seagate 40 GB HDD+ 80 GB HDD IDE Sony Dru-810a dvd rw Realtek ethernet card |
#12 (permalink) |
check this out.
the LAN time shows 1 day. i used rapidshare.i am not able to use only torrent . i have opened all ports but i don't know why the modem freeze only happens with TORRENT Last edited by techtronic; 17-06-2006 at 12:09 AM. |
#13 (permalink) | |
Even I am experiencing the same problem....but if i use bittorrent,or lime wire this problem doesnt arise only when I use Azureus I have UL 900 Plan I use a compaq presario b1800 note book. 2 ghz,504 mb ram windows xp service pack 2 modem MT880 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
