| Forum |
#1 (permalink) |
I wish to upgrade my P-III machine with an AMD based machine. I have finalised all the components except the Cabinet and power supply unit. PLease suggest a good cabinet with appropriate cooling and a good PSU. Total budget = Rs 2000. thanks in advance...
Intel Core 2 Duo E6300, Intel DG965RY, MSI 8600GT OC, WD 250GB SATA-II Harddisk, Transcend 1GB 667 Mhz DDR2 RAM, Samsung Samtron 55V, Sennheiser HD485 cans, Zebronics LAVA Cabinet, Zebronics 400W PSU |
#2 (permalink) |
-The BlacKCoaT Operative-
hey i am also looking for a new cabinate at<2k..
i have amd 3000+ on A8N SLi and 3 HDD + 3 Optical my present case does not provide good cooling to the hdd(55degrees) as it is thin metal...
-------------------------------------------- Holding my last breath, safe inside myself..... -------------------------------------------- I dont use my computer. I misuse it- रोलरकोस्टर |
#3 (permalink) | |
V.Prem Kumar |
#4 (permalink) |
Listen i u increase ur budget fer the cabinet, u can get a Zebronics Antibiotic which is a cool gaming cabinet has 3 pre-installed fans and even has a temp. display.....the fans have tri-colour LEDs.....it is for Rs 2300
and Zebronics is an Indian companty so there won't be much problem in availability te web address is: http://www.zebronics.net here's a pic. |
#5 (permalink) |
hey is that cost inc. of the PSU, i saw somewere that their psu is not good..
can i get one without the PSU and can anyone tell me how to get it in dehradun.
#6 (permalink) | |
BTW Zebronics has PSUs (which are said to be of very good quality) that cost many times the mentioned budget of Rs.2300/- for both PSU and cabinet. They do have diff series of PSUs like ordinary, Gold, Patinum etc.
V.Prem Kumar |
#7 (permalink) |
well i had just bought a 500watt PSU.. so i wanted to know if they have option to buy just the cabinet...
#8 (permalink) | |
V.Prem Kumar |
#9 (permalink) |
i got a odyssey 2005 500W model 500PA.... cost is nil as it was some adjustment n stuff. It was supposedly the best cheal psu
#10 (permalink) |
I can remember that name.
My existing cabinet is odyssey (250W) ATX. It's quite a large cabinet. Finally, can anyone suggest a good cabinet +PSU under 2K...
#11 (permalink) |
the above spcified Zebronics cabinate looks real cool... can anyone give other options and their availability in north india
| Bookmarks |
| Thread Tools | |
| Display Modes | |
