hi there i also bought the same mic as you bought but my mic is not working in windows 98 but is working in xp.can you help me out.i know how to make the mic work in xp .go to advanced setting of volume control of mic and switch on the microphone boost.
i have HD audio capture frm MS........It does not show volume control like ur does......it only has Master Volume, Wave Synth and CD Player Volume control..........
hey there
do this:-
start>programs>accesories>entertainment>volume control.
then switch on advanced controls from options.a tab will show below microphone.click it and you are there.by the way do some experimenting with your computer do become the ultimate guru of it.if it works please click on thanks.
