Old 13-06-2006, 06:56 PM   #1 (permalink)
56561's Avatar
Default best speaker? Rs > 10k
which speaker gives the best sound effect for movie & gaming ? I am a movie freak and I want cinema hall effect in my computer . So I want to buy the best speaker for Rs 10k .
how about THX certified speakers?
I heard DVD is made for 5 channel again my motherboard has 8 channel audio .what these mean?
56561 is offline
Old 13-06-2006, 07:53 PM   #2 (permalink)
royal's Avatar
Wink Re: best speaker? Rs > 10k
try Logitech Z-5300 ... costs around 11K
You wont regret it
and yeah... it is THX certified
find more info here
royal is offline
Old 13-06-2006, 08:05 PM   #3 (permalink)
samrulez's Avatar
Default Re: best speaker? Rs > 10k
check out this
Speakers "THX certified" ???
Sam Rulez
samrulez is offline
Old 13-06-2006, 08:57 PM   #4 (permalink)
dOm1naTOr's Avatar
G for Logitech Z5300...its hell of the best for the price
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 13-06-2006, 09:51 PM   #5 (permalink)
pedal to metal
suave_guy's Avatar
if u really want to enjoy good quality mutichannel sound than i wud suggest u to go for external sound card also preferably from creative audigy series along with ur speakers coz onboard soundcards are weak in rear channel effects and also lacks aural fiedility...
so if u want to do justice to ur good speakers like logitech z-5300(which i suggest u to go) than avoid onboard sound...
ENjoy...
your "attitude" is your best friend...
suave_guy is offline
Old 14-06-2006, 12:35 AM   #6 (permalink)
Official Techie's Avatar
why dont u see last months mag
Game Khelwanu Magazine Padhwanu Majjani Life
http://sudiptatech.blogspot.com/
http://sudiptamondal.blogspot.com/
Official Techie is offline
