| Forum |
#1 (permalink) |
I had assembled my PC a few months back (1st time) The specs are Intel p4 HT Chip Intel D915gav MOBO 512 MB Kingston Ram (1 DIMMS) 120 GB SATA HDD 1 DVD - RW (Sony) 1 DVD - ROM (Sony) Total Two Optical Drives 1 FDD XP Professional Graphics and Sound are onboard This worked fine for about 6 months then recently it started giving problems. The PC would refuse to boot up sometimes. The lights come on. and the fans start but there is no display But when it does boot up there are no problems it works just fine I got my PC checked by my local PC wallah and he asked me to get the MOBO Checked which i did and i was told there is no problem with the mother board Then i was told that perhaps the power suppy was not adequate(i had a 250W SMPS). I changed this to a 400W Frontech SMPS This seemed to have solved the problem but then after a day or so it started again and now this time no abount of fiddling seems to make it restart. Please tell me what might be the problem thanks -Tushar |
#2 (permalink) |
GUNNING DOWN TEAMS
First and formost try checking if ur ram chip is functioning.........try using in other slots adn check if it helps.......tryusing it in friends computer....to see if its functioning.........post in results......
The moment U stop learning ......u stop improving |
#4 (permalink) |
Hi
Im A little confused. did you change it to a Mercury 400W Smps or did u change it from a mercury 400w Smps? If u changed from a Mercury SMPs which one did u use? and can you tell me the cost ? thanks i am using a Frontech 400W smps Do they make good SMPS? let me know thanks |
#5 (permalink) |
Let the music play.....
Hey I also think its ur ram that is problematic coz I also had the same problem and had a helluva problem trying to fix it up. So then what u can do is take ur ram to a friends machine and check it. If it doesnt work or gives any problems u might know. To check the ram try unzipping rar and/or zip files most of them give crc errors when the ram is faulty. U can also get ur friends ram to check out ur machine and then u might get the fault sorted out.
Long back, a person who sacrificed his sleep, forgot his family, forgot his food, fogot laughter were called "Saints" But now they are called.."IT professionals" |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
