Old 12-06-2006, 04:42 PM   #1 (permalink)
Unhappy PC3200 not showing 400Mhz in CPUZ!!!Please help
Guys,
Here is what CPU-z shows in the memory menu:
Channels #-Single
Type-DDR
Size-1024 MBytes
Timings:
Frequency-200.9 Mhz
FSBRAM-CPU/11
CAS# LAtency-3 clocks
RAS# to CAS# Delay-3 clocks
RAS# Precharge-3 clocks
Cycle time(Tras)-8 clocks
Bank cycle time(Trc)-11 clocks
Command rate-1T
DRAM idle timer-16 clocks
Please tell me why is it showing 200.9 Mhz. Is it because my CPU is clocked at 200.9 *11=2210 Mhz?
Is it not 400Mhz then?
One more prob:
In my AMI-BIOS menu, within advanced chipset features:
HYPERTRANSPORT CONFIGURATION:
CPU to NB Freq. -[1000 Mhz]
NB to SB freq.-[800 Mhz]
CPU to NB linewidth[16|16]
But for NB to SB freq. there is another option 1000Mhz. Can I set it to that??? The rest is at its max. What's this crap-****??
By-the-by how safely can I Oclock my CPU with the same heatsink-fan combo? [In the freq settings it is displayed from 200.0 to 250.0.]
{Besides @Janitha, @samrulez and @deathvirusme , My HDD has strictly 2MB buffer. Will it cause any prob in performance?}
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 12-06-2006, 05:06 PM   #2 (permalink)
dIgItaL_BrAt's Avatar
Default Re: PC3200 not showing 400Mhz in CPUZ!!!Please help
you're using DDR RAM,where data is transferred on both the rising and falling edge of the clock pulse,so the actual frequency of your RAM is 200x2=400 Mhz.
dIgItaL_BrAt is offline
Old 12-06-2006, 07:13 PM   #3 (permalink)
Why you are using a single 1 GB Ram stick when you have a dual channel capable Mobo. Either get another similar 1 GB stick or sell the one you are having and get two identical 512MB Rams. I think this is the first thing you should do.
The 2MB cach is not likely to make much difference but 8 MB would have been better.
V.Prem Kumar
janitha is offline
Old 12-06-2006, 08:16 PM   #4 (permalink)
samrulez's Avatar
U are using DDR (Double Data Rate) SD ram...so the speed of the SD ram is 200 MHZ e.i double so 200X2= 400 MHZ
Sam :D Rulez :lol:
samrulez is offline
Old 13-06-2006, 03:49 AM   #5 (permalink)
deathvirus_me's Avatar
speed of the ram is 200 MHz ... the rating is ddr400 coz its a double data rate mem. .. so u can read/write at the same time ... so sums upto 400 MHz ... but the actual operating frequency is 200 ... true for all ram .. i mean .. ddr266 at 133 MHz , ddr333 at 166 MHz etc. etc.
Yes.. . yes. .. thats right ...
Well .. i used the same mobo for some days and at that time i had it set to 1000 MHz and everything was rock stable .... so i guess u already have ur answer ...
deathvirus_me is offline
