Old 12-06-2006, 07:23 AM   #1 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Lightbulb Buying cpu from abroad
I have almost decided to wait and buy conroe E6400 when it comes out in July. And from what I have read I would have wait for a long time for conroe in India.
SO tell me ppl, is it feasable to buy the cpu from abroad (usa) , then buy a compatible mobo, psu, ram locally and assemble everything at home.
Or could there be problem regarding voltage / connections or anything else.
Thanks!
chesss is offline
Old 12-06-2006, 08:16 AM   #2 (permalink)
Your Maker.
MysticHalo's Avatar
Default Re: Buying cpu from abroad
I wonder how the compatible mobo will be available here if the proccy wouldnt be Better get Proccy+Mobo both from abroad.
Thanks!
Not unless u choose the correct products.
“Talent is a flame, but genius is a fire.”
MysticHalo is offline
Old 12-06-2006, 09:47 AM   #3 (permalink)
Thats beacause motherboards supporting conroe are already out . I guess intel 975 chipset supports conroe
cyrux is offline
Old 12-06-2006, 12:23 PM   #4 (permalink)
chesss's Avatar
Cool. So what all should be checked (voltage/connector etc) before buying to ensure a correct match?
Yup conroe is 'unofficially' supported by a very few mobos.
And from what I have read , they aren't too expensive (4k) .
Conroe looks like such a dream : low power(65W), awesome speed, virtualization, and cheap. Heres a great link link for those interested in knowing more.
chesss is offline
Old 12-06-2006, 01:54 PM   #5 (permalink)
samrulez's Avatar
I feel u should get the mobo and processor both from USA.......
and just check how much power does it consume...
And I think a Antec True Power 2.0 550 watt SMPS will be
enough..but to be on the safe side get the mobo+processor+SMPS(if it uses some different kind of SMPS)
Sam :D Rulez :lol:
samrulez is offline
Old 13-06-2006, 04:31 AM   #6 (permalink)
chesss's Avatar
That would be too much to carry .
As for different kind of SMPS, I would love to know exactly how psus requirement can be different. Anybody with technical knowledge?
chesss is offline
Old 13-06-2006, 07:23 AM   #7 (permalink)
samrulez's Avatar
It should have 550 watt with a good amp rating across each output....
+3.3V,+5v,+12v -5v,+5VSB......
Make sure u have atleast a rating of 20 amps across +12V...
Sam :D Rulez :lol:
samrulez is offline
Old 14-06-2006, 01:37 PM   #8 (permalink)
chesss's Avatar
k, Many thanks . Though I doubt I would need 550 Watts, conroe has a tdp of 65W and I wouldn't need a GPU
chesss is offline
Old 14-06-2006, 09:58 PM   #9 (permalink)
samrulez's Avatar
hmm...then a 400-450watt SMPS from Antec or some other good one will do..
Sam :D Rulez :lol:
samrulez is offline
