Old 10-06-2006, 06:00 AM   #1 (permalink)
Official Techie's Avatar
Default pci cards
are pci cards still in existence if yes suggest me a good one
Game Khelwanu Magazine Padhwanu Majjani Life
http://sudiptatech.blogspot.com/
http://sudiptamondal.blogspot.com/
Official Techie is offline
Old 10-06-2006, 07:42 AM   #2 (permalink)
nishant_nms's Avatar
Default Re: pci cards
what do u mean by PCI cards? Do u mean Graphic PCI card. If so then they are now non-existent in the market.
all other addon cards like soundcard, modem, etc. are available in pci, they have not moved to pci-x
nishant_nms is offline
Old 10-06-2006, 07:47 AM   #3 (permalink)
eagle_y2j's Avatar
PCI (peripheral component interconnect) is running technology in market for many devices like PCI modem,Sound Card ,PCI-wifi,Lan cards and much more and till now every mobo is coming with atleast 2 slots..........
Hence Proved that pci cards still in existence
Registered LINUX USER #438929
eagle_y2j is offline
Old 10-06-2006, 07:48 AM   #4 (permalink)
ya i mean pci grapjhices card i thought of buying one good one
Old 10-06-2006, 11:05 AM   #5 (permalink)
You can get a PCI graphics card but it won't be any good for newer games.
drvarunmehta is offline
Old 10-06-2006, 11:39 AM   #6 (permalink)
samrulez's Avatar
U will get a PCI based graphics card....but..it will be really,really be of no use for playing games......
Sam :D Rulez :lol:
samrulez is offline
Old 10-06-2006, 05:28 PM   #7 (permalink)
i have an old 815 mobo it has agp slot are agp cards better
Old 10-06-2006, 05:29 PM   #8 (permalink)
Back From Deathstar
Darthvader's Avatar
definitely yaar, PCi cards are worthless and since u have a agp slot y worry
Get any AGP card
Darthvader is offline
Old 10-06-2006, 05:32 PM   #9 (permalink)
ok suggest an agp card in less than 6 k and will it run games like fear mfsmw etc
Old 10-06-2006, 05:34 PM   #10 (permalink)
can i also play online games i have a broadband conn suggest a free one like ragnarok
Old 10-06-2006, 05:34 PM   #11 (permalink)
Back From Deathstar
Darthvader's Avatar
Well stretch it to around 7k and u will get a 6600gt which is the best bang for buck card available
Old 10-06-2006, 05:44 PM   #12 (permalink)
will this card be suitable for agp slot and will all latest games run on it
Old 10-06-2006, 06:58 PM   #13 (permalink)
You have a 815 mobo which means you have a Pentium III processor and SD RAM. No matter which graphics card you buy, you can't play games because the rest of the system is really slow. You'll just have to buy a whole new rig.
Old 10-06-2006, 08:11 PM   #14 (permalink)
samrulez's Avatar
XFX 6600.......5 k
XFX 6600GT...7.5k
Sam :D Rulez :lol:
samrulez is offline
Old 14-06-2006, 12:20 AM   #15 (permalink)
i have p4 2.02 ghz and underground runs on it
Old 14-06-2006, 08:43 AM   #16 (permalink)
But didn't you write that you have an 815 mobo? Then how come you have a P4?
Old 14-06-2006, 09:12 AM   #17 (permalink)
see i have p4 512 ram 80 gb hdd 845 mobo but it supports only pci cards but 815 also supports agp cards so i would like to buy one agp card
Old 14-06-2006, 09:35 AM   #18 (permalink)
dOm1naTOr's Avatar
I fear dat the older 815 mobo has 2x AGP nd todays 8x cards are only compatible on 8x or 4x slots. Even the voltages employed on 1x/2x and 4x/8x are different.
So i suggest get a cheap 845 mobo with AGP slot nd buy a Gcard say a 6600non GT. Dun waste money on GT as the other system config is low nd u can't utilize it to the maximum nd a 2Ghz intel proc is bare min for todays games.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
