Originally Posted by Official Techie
i tried opening my dvd drive but could not do so coz there were no screws to open then my dad gave me permission to buy a new lite-on dvd writter Gud Gud Gud
I have done it after searching for tips from the web. Once you know the method it is very simple. There are some plastic lugs which keep it locked, which you have press for opening. But do it very slowly and carefully. Or entrust to a technician who can open and clean it within ten minutes without any special tools. Better use only lens cleaning liquid used by photogrphers and avoid isopropyl alcohol normally used by technicians.
If in the warranty peiod, do not try to open or repair. And if it is very old, say 3-4 years, there is possibility of its laser having become weak. If so, replacement would be better.
