Old 08-06-2006, 02:01 PM   #1 (permalink)
Extheist
aditya1987's Avatar
Default Help!!!!!!!!!! 512 converted to 256 ????
Please help me!!
Recently I got flash based mp3 player (512 MB) from chinese maker :-
http://i16.ebayimg.com/01/i/07/4f/a0/b9_1_b.JPG
It was runnig very well but when I formated it, it's memory went down to 256 MB.Please someone tell me how to recover the remaining 256MB.
Waiting for you reply!!
aditya1987 is offline
Old 08-06-2006, 08:14 PM   #2 (permalink)
samrulez's Avatar
Default Re: Help!!!!!!!!!! 512 converted to 256 ????
Just format the other partition with some s/w other than the bundled one...
Sam :D Rulez :lol:
samrulez is offline
Old 08-06-2006, 08:47 PM   #3 (permalink)
Extheist
aditya1987's Avatar
I did not get any bundled software and which one should I use???
Old 08-06-2006, 09:19 PM   #4 (permalink)
samrulez's Avatar
U can use any partitioning s/w with has support for flash drives...
Sam :D Rulez :lol:
samrulez is offline
Old 08-06-2006, 10:34 PM   #5 (permalink)
My 128 mb also went down to 32 mb in 1 yr. It was from kingston.
n.regmi is offline
Old 08-06-2006, 11:13 PM   #6 (permalink)
Theres always a CD which u get with the flash player...The CD has a utility for formatting da disk....And the filesystem used is dufferent, so u HAVE to use da software provided by the manufacturer...Try to procure it aditya & format ur flash drive using it...
h_kunte is offline
Old 08-06-2006, 11:27 PM   #7 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Originally Posted by aditya1987
Please help me!!
U have the answer....see BOLD words
Do not trust these chinese makers without any repu.....they make cheap stuff..
If its NEW then y not get it replaced....
wizrulz is offline
Old 13-06-2006, 08:34 AM   #8 (permalink)
even i got the same thing and have the same problem with that player.
these players are formatted by the manufacturer and the memory is compressed so when you re-format it it reduces to half
so i will suggest you not to do any thing to your player and enjoy 256 mb as you can end up destroying that too
also see "http://www.s1mp3.org"
rag_kak is offline
Old 13-06-2006, 09:21 AM   #9 (permalink)
dOm1naTOr's Avatar
Earlier there was a thread similar to this. Actually cheap ones only has half or even less capacity and shows a big value by flashing it or some other s/w means. If u dun have formatted also u couldn't use the mem greater than the real one nd trying to use them causes s/w problems nd we try to formatt it nd the truth comes out. Its same with all cheap flash based MP3s.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
