why would anyone want to disable L2 cache?
it is there to keep data frequently required by the procesor and is extremely fast(in some cases as fast as the processor itself)
As it would take much much longer for data to be fetched from the RAM of the system. It is just anologus to asking should i remove all of the RAM of my computer. Because RAM is for the same reason,it provides faster access to frequently required data, and if u were to disable the RAM then all data wouldhave to be fetched from the HDD and would cripple the system is terms of speed.
here are a few links:
What is L2
http://www.cyberwalker.net/columns/dec99/091299.html
http://en.wikipedia.org/wiki/L2_cache
Disable L2 Cache:
Check in the biso to see if u have the following options
CPU Level 1 Cache
Options : Enabled, Disabled
This BIOS setting can be used to enable or disable the CPU's L1 (primary) cache. Naturally, the default setting is Enabled.
This feature is useful for overclockers who want to pinpoint the cause of their unsuccessful overclocking. I.e. if a CPU cannot reach 500MHz with the L1 cache enabled and vice versa; then the L1 cache is what's stopping the CPU from reaching 500MHz stably.
However, disabling the L1 cache in order to increase the overclockability of the CPU is a very bad idea, especially in highly pipelined designs like Intel's P6 family of processors (Pentium Pro, Celeron, Pentium II, Pentium !!!).
CPU Level 2 Cache
This BIOS setting can be used to enable or disable the CPU's L2 (secondary) cache. Naturally, the default setting is Enabled.
This feature is useful for overclockers who want to pinpoint the cause of their unsuccessful overclocking. I.e. if a CPU cannot reach 500MHz with the L2 cache enabled and vice versa; then the L2 cache is what's stopping the CPU from reaching 500MHz stably.
Users may choose to disable L2 cache in order to overclock higher but the trade-off isn't really worth it.
