Old 07-06-2006, 12:09 AM   #1 (permalink)
Default Need to connect two PCS
Hey dudes,
Recently i came across a problem.
I need to connect two PCS via USB ports.
How can i do that.??
Please note that i need to connect using USB and not crossover cables.
Will a USb-USB cable will suffice.
System Of A Down is offline
Old 07-06-2006, 02:13 AM   #2 (permalink)
Eazy's Avatar
Default Re: Need to connect two PCS
Take CARE !!! It is NOT recommended to use a normal USB cable to connect 2 computers - read this page for more info...
http://www.hardwaresecrets.com/article/248
Eazy is offline
Old 07-06-2006, 09:45 AM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
U need a bridge/hub type of usb cable to do so... not those normal ones, they wont work...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 07-06-2006, 08:37 PM   #4 (permalink)
dOm1naTOr's Avatar
Its gr8. USB for connecting 2 PCs?? Is it faster nd can play multiplayer games in lan?? Nd how much does all the setup cost?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 07-06-2006, 10:58 PM   #5 (permalink)
samrulez's Avatar
GR8 but connecting 2 comps on LAN would be much cheaper and easier....
Sam :D Rulez :lol:
samrulez is offline
Old 10-06-2006, 12:33 PM   #6 (permalink)
....... and a much better option IMHO. All you need is 2 el-cheapo LAN cards and a crossed LAN cable.
Keith Sebastian is offline
