06-06-2006, 10:17 PM
Which way to opt AMD or Intel?
I am upgrading my current system (2.8Ghz processor on i845 mobo) as my system doesn't have any Graphic slot(AGP ,PCI-e ) many other features like SATA,Onboard LAN etc.
My main purpose of my system to run smoothly Vista and do some multimedia work on Photoshop,Flash etc and some gaming but the main problem is that I am not sure to which platform to choose either Intel or AMD .Till now I faced no problem from Intel but I came across one article in some of the websites that AMD is gud perfomer than Intel and cost effective also so ,can any1 help me out to make wise decision .
And also suggest me mobo+cpu including following features
My Budget is upto 12,000 bucks max for Mobo+CPU
I am looking for following feature
MObo
1.PCI-e slot
2.Sata
3.DDR 2*
4.Onboard LAN, Graphics,Sound
5.Dual core CPU support*
CPU
Gud performer and cost effective (If possible plz quote price for dual core )
And lastly ...I am wanna sell out my old mobo+processor i.e orignal Intel 845GVSR+2.8 Ghz (533Mhz 512Kb cache) my delear is ready to buy this for 5500Rs .Is this is a right price for 2 year old machine
Registered LINUX USER #438929
06-06-2006, 10:56 PM
Re: Which way to opt AMD or Intel?
amd i think...in short
but do checkout properly...i guess dual-cores from intels r kool...
cheers
No Pain...No Gain
06-06-2006, 11:00 PM
bang bang!
U can go for the following config. I have it and it jst rocks.
Amd 3200+ with Asus A8n-e(my mobo is without onboard gfx) so if u want onboard gfx than go for Asus A8n-vm. I gor amd 3200+asus a8n-e for 13k at the end of Feb. 06. Don't know current prices. If it is above 12k than u can got for amd 3000+ with asus a8n-vm.
AMD 3800+X2 is dual core processor but its current price is 13k-14k as far as i know. So i think u shld buy amd 3200+ or 3000+.
06-06-2006, 11:35 PM
Commander in Chief
I suggest an Intel too, considering you are using Pshop and stuff of multimedia... try a low 820 dual core of 2.6 GHz, it can be safely oc'ed to 4~ ghz  Awesome!
Harsh J
www.harshj.com
07-06-2006, 12:10 AM
U can easily get a Pentium D 805 costing only $130 and a intel 945 xx based mobo from ASUS...
Sam :D Rulez :lol:
07-06-2006, 06:06 AM
wat abut Intel® Pentium® D Processor 820 can any1 quote its price (Indian)
and suggest a mobo for it
07-06-2006, 06:47 AM
GaurishSharma.com
07-06-2006, 12:53 PM
Intel for photoshop, dual core with 256-512mb geforce 7600 or X1800 series provided you don't game much
07-06-2006, 01:06 PM
for games its certainly amd64 may be x2...
cheers
No Pain...No Gain
07-06-2006, 02:51 PM
Your Maker.
Wait till Jan for Intel quad-core conroe
“Talent is a flame, but genius is a fire.”
07-06-2006, 04:07 PM
dude,that'll be way out of his budget.
07-06-2006, 04:16 PM
Hey! frnds plz suggest me a gud mobo for Intel dual core cpu
07-06-2006, 04:54 PM
Pentium D 805 with Intel 945GNT for intel
Asus A8N-VM with Athlon64 3200+
07-06-2006, 08:20 PM
Any comments............!!
07-06-2006, 08:33 PM
Your Maker.
Oh...lol...yes i never read that red printed budget thing. Ok then, u gotta stick with an AMD 3200+ and the usual A8N-E/VM mobo.
Or D 805..but its crappy...i dunno abt its overclocking as qwerty said...but...:S
Yeah 5500 is gud enough for a 2 yr old rig...check online if some1 is wiling to pay higher
07-06-2006, 09:28 PM
Being a hardcore AMD fan Im reccomenting Intel to somebody for the first time as the reasons are:
Vista support in least cost
DDR2
Dual core
The 945 mobos onboard Graphics named somewhat 950GMA(not sure as I was not interested in Intel articles) supports Vista 100% with all the tranperencies. Go for a Pentium D 805 nd supports DDR2 upto 667Mz.
As for AMD DDR2, Dual core all are extremely expensive as DDR2 support is only for newest AM2 socket which could be a killer in price. The lowest dual core X2 3800+ costs 15k+ for proc itself(but is worth the money). And only 7 series nvidia supports Vista 100%. A 7300LS costs around 6k. That is a lot of money..
But for Intel u can get vista ready disply, dual core nd DDR2 support for very less price but at the trade of perfomance which I think u don't bother as price is as low.
G3: XPS M1530 |
FZ 16.
07-06-2006, 10:12 PM
If u go for Pentium D then don't go for original intel mobo....I've heard that ASUS boards are better than O.G intel ones ....so go for ASUS 945 PL mobo based in Intel 945 chipset.....
And 945 mobo is fully Vista ready!!!!
Sam :D Rulez :lol:
09-06-2006, 09:02 PM
and (allegedly) it can be OC'ed to > 4 Ghz (per core) on air cooling alone. Check out anandtech.com (or was it tomshardware.com ?)
Cheers,
Keith
09-06-2006, 10:43 PM
#19 (permalink)
Can the 945 run DDR1?
If yes then go for DDR1 memory coz u will get a 2.5 CL ram at minimum.....and cheap DDR2 offers higher latencys...So don't go for DDR2 unless u are getting a good DDR2 with low latency....
Sam :D Rulez :lol:
09-06-2006, 10:49 PM
#20 (permalink)
Commander in Chief
Yes all DDR2 supportive slots have backward comaptiblity with DDR =)
Harsh J
www.harshj.com
10-06-2006, 07:59 AM
#21 (permalink)
@ QwertyManiac
If Im not wrong, DDR2 slots are much bigger than DDR1. As Im an AMD fan i was not able to see a DDR2(damn), nd the voltage rating is also different, then how come it is backward compatible with older DDR????
This is the ionformation Ive got from the mags...
G3: XPS M1530 |
FZ 16.
10-06-2006, 10:01 AM
#22 (permalink)
You can't have a DDR 2 if you go for an AMD proc.
Intel dual core 2.66 GHz will cost you about 5900-6200 bucks.
10-06-2006, 12:19 PM
#23 (permalink)
Originally Posted by aravind_n20
@ QwertyManiac
Yep DDR-II is not backward compatible. The pin count is 240 as opposed to 184 of DDR. Also, the notch on the RAM stick is at a different position. So you cannot accidentally force DDR into a DDR-II slot or vice versa.
- Keith
10-06-2006, 07:13 PM
#24 (permalink)
but till now nobody recommended me a gud mobo+CPU (AMD)?
10-06-2006, 08:10 PM
#25 (permalink)
Okay.....Can u increase ur budget by 6K then u can go for a AMD 3800+ X2 and a ASUS A8N-E
OR go for a 3500+ (Venice) and a ASUS A8N-E or A8N-VM....
This will be enough for for ur need.......
Sam :D Rulez :lol:
10-06-2006, 09:47 PM
#26 (permalink)
If its AMD the choice starts here!!!!!
**AMD 64 X2 4400+@dun know(Extreme perf with 2x1mb cache)
**AMD 64 X2 3800+@13~14k (costly it might seem, but defenitely worth it 2x512kb)
**AMD 64 3500+ @9.5~10k (extreme perfomance in overall single threaded apps and good compared to dual cores in multithreaded apps)
**AMD 64 3200+@7k (Good perfomance and very good value for money and has potential to oc to hogh values)
**A8NE @ ~5.5k (Very good mobo with tons of everclocking options and rock solid with nf4 ultra)
**A8N SLI Deluxe@8k (SLi ready, highly ocable, great value SLI mobo,nf4SLI)
**MSI K8N Diamond@8~9k(SLI ready, ocable, creative 24bit 7.1 onboard audio, tons of features, nf4SLI)
All of these are 64 bit and vista compatible. If u add a GF7 series card u can enjoy the transperencies and other visuals in Vista (At least a FG7300@5k)
All of these mobos(and proc) supports only DDR1 (but at ultra low latencies) but could produce higher memory bamdwidth scores than DDR2 on Intel if u use quality rams with low latencies and good mobos(above ones).
For the mentioned price ur best choice(if AMD) would be a 3200+9 with an A8N E mobo.
G3: XPS M1530 |
FZ 16.
11-06-2006, 06:17 AM
#27 (permalink)
hmmmmmm it seems I hav to add some more fund to my budget . K I can stretch upto 16000 .but which 1 is gud choice for me
1.Intel D 820+945 ASUS P5LD2
2.AMD 3800+ X2 and a ASUS A8N-E
Which of above is a gud performer and and will run smoothly to next 2 years.
11-06-2006, 07:24 AM
#28 (permalink)
AMD AMD AMD...its hell of the bast yaar...its stock speed is 2ghz and it can be easily overclocked to 2.6 with stock cooling and above with good cooloing. Isn't it gr8??? U can hear bout personnel xperience of freaks who own such proc from xbitlabs forum or some other worldwide forums or tomshardware. And nothing much to say bout A8NE..do we..
But intel procs suck...running at higher clocks and generating more heat. Also for AMD u can go for comparatively cheaper SLI solution mobo even from ASUS(A8N SLI) at 7.8k or less. But for intel SLI mobo is sure to cost a bomb.
G3: XPS M1530 |
FZ 16.
11-06-2006, 01:15 PM
#29 (permalink)
Huh ??? Conroe is supposed to be dual core no ??? And that quad core thingy .. isn't the K8L being developed by AMD ???
And about the upgrade .. go for a P4 EM64T processor with a 915 mbo .. with a guaranteee of 600 MHz oc with ddr333/400 ram ... it should beat the corresponding AMD ... hell i mean .. get a 2.8 .. and run it at 3.4 ....
11-06-2006, 01:26 PM
#30 (permalink)
AMD 3800+ X2 and A8N-E would be much better...3800+ X2 is better than even P D 9xx...
So just get a 3800+ X2....u will be happy with it.....
Sam :D Rulez :lol:
