06-06-2006, 07:54 PM
How important is Earthing ? ? ?
hey guys pls tell me what happens if i dont hav proper earthing in the house, i get shocks in my cabinet. Does it effects any parts.
06-06-2006, 08:14 PM
Re: How important is Earthing ? ? ?
Dude it won't effect the components but it will surely effect u!If u get a live 230 V shock u can also lose ur life....get the earthing in the house fixed.. OR is it in only ur cabinet???Then change the SMPS..
Sam :D Rulez :lol:
06-06-2006, 08:34 PM
-The BlacKCoaT Operative-
earthing is definately important from the users' point of view but it is equally important from the electronics pov.
Consider this... your case give a little electricity feeling(which i am sure most of us are very very familear with in india) means it is not earthed properly. Now if u are handeling the insides of the computer like (un)installing devices by hand then you component are at large risk becuase when ur hand or anything conductive for that matter touches the bare contacts of SMD components then the current can flow thru them. we al know how sensitive electronic stuff is. that is y it is recomended to disconnect electronic devices from the powers sockets. althought the 1st thing is human saftey but i guess humans are more tolerable to electronic shocks then on board chips and transistors.
06-06-2006, 10:37 PM
Rollercoaster wrote
"humans are more tolerable to electronic shocks then on board chips and transistors"
very correct. Proper earthing is essential for proper functioning and durability of the computer and its components. To be sure, ensure that the voltage between the Earth and Neutral of the mains power is as minimum as possible. If necessary and possible, give separate earthing for the computer.
V.Prem Kumar
07-06-2006, 10:34 AM
dude,its extremely important
get that earthing...ur PC wil thank you
26-03-2007, 01:57 PM
Welcome To The Jungle
earthing is very important for all ur electrical devices and for ur home too.
Me n My Canon EOS 350D with EF 50mm f1.8
26-03-2007, 02:09 PM
gEttIn 0uT@@@ BOXX
It entirely depends on uer luck .. it might not effect your sys for years and sudenly one fine day .. u c uer sys crash or some ;component roasted .. u can never say when will it cast it's ill shadow .. so it's always better to get the earthing done when runnin any tronics
Koi CHAKAR NAHI HAI >> SAB JUGAAD HAI
27-03-2007, 02:06 AM
Rising ApocalypsE
Man these fricking chips are so sensitive that they got fried with your body current(static Charge)!!!
Thats why these all comes in anti-static bags(those dark colored polythene bags).
28-03-2007, 12:49 AM
www.indianangler.com
i don't hav proper earthing also...thanx for the post, i'll fix it in a few days
when the going gets tough, the tough go.....fishing!!!
29-03-2007, 08:52 PM
Evil Genius
Shocks are fun! Bzzzzt...hehehe..tingly!
Roses are #FF0000, Violets are #0000FF...All of my base are belong to you!
29-03-2007, 09:50 PM
Well so far nothing happened to the computer. Only thing that was sensitive was me. I get shock everytime i touch my cabinet  . So much for chip senstive.
30-03-2007, 02:38 PM
Try touching the screen of your CRT monitor without a proper earthing...
Gawd, I had great fun playin pranks on my frnds with that thing.....
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
30-03-2007, 11:01 PM
Rising ApocalypsE
 oh yeah!!! Well dude abhi has already mentioned,its your luck.Sometimes hardware hardwares have long life without earthing or some ran out of luck sometimes.So the best part is to stay on the safer side.
